Site to Site, Encrypt tunnel
1mroberts
I have point to point T1 with 2x2811 routes. I need to Encrypt the data passing between the two routers. I have tried using and several types VPN of tunnels with limit success. Pings and trace routes work but none of my application work.
royalblues
Level 10
Level 10
Can you post your configs
Here is a sample we do
Router 1
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key address
crypto ipsec transform-set test esp-3des esp-md5-hmac
crypto map test 1 ipsec-isakmp
set peer
set transform-set test
match address 105
access-list 105 permit ip
Router 2
encr 3des
hash md5
set peer
match address 105
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
Narayan
Mike,
If you are able to ping and tracerroute after VPN tunnel comes up then there mayn't be a configuration issue. The symptom you described about the application connectivity issue frequently happens as a result of MTU problems due to IPSEC overhead. Can you try configuring the command 'ip tcp adjust-mss 1440' under the ethernet interface facing the LAN and test your applications.
If you are still having issues then can you provide us a sanitized a copy of the configuration.
Sundar
Joseph W. Doherty
When you note ping and trace route work, you're sure they are using the actual tunnel? Also, do they work from devices on the LAN sides or sourced from the routers' LAN interfaces?
