Site-to-site ipsec vpn - unable to ping remote network
Piotr Pawlowski
Dear all,
I have two Cisco routers - 2911 in HQ and RV180 in branch office.
Because in HQ LAN network I have some development servers, to which guys from branch office need to have acces, I decided to setup VPN site-to-site between HQ and branch office.
Everything went quite smoothly, on both devices I see, that ipsec connection is established. Unfortunately I am not able to ping resources from one network to other one and vice versa.
Below is the configuration of 2911 router (I skipped som unimportant (imho) configuration directives) :
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
crypto isakmp key MyKey address 78.133.254.114
crypto ipsec transform-set GLIWICE esp-3des esp-md5-hmac
crypto map GLIWICE-MAP 1 ipsec-isakmp
set peer 78.133.254.114
set transform-set GLIWICE match address 190
interface GigabitEthernet0/0
description LAN
ip address 10.0.0.1 255.255.254.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description TASK
ip address 213.192.65.106 255.255.255.252
ip access-group 101 in ip nat outside ip virtual-reassembly in duplex auto speed auto crypto map GLIWICE-MAP service-policy input skype-policy service-policy output skype-policy
ip default-gateway 213.192.65.105
ip forward-protocol nd
ip nat inside source route-map nat_isp1 interface GigabitEthernet0/1 overload
ip nat inside source route-map nat_isp2 interface GigabitEthernet0/2 overload
ip default-network 213.192.65.105 ip route 0.0.0.0 0.0.0.0 213.192.65.105 track 1
ip route 0.0.0.0 0.0.0.0 193.107.215.129 track 2 ip route 10.0.100.0 255.255.255.0 GigabitEthernet0/1
access-list 110 permit ip 10.0.0.0 0.0.1.255 any
access-list 190 permit ip 10.0.0.0 0.0.1.255 10.0.100.0 0.0.0.255
route-map TASK permit 10
match ip address 110
match interface GigabitEthernet0/1
route-map track_isp permit 10
match ip address 101 match interface GigabitEthernet0/1 set ip next-hop 213.192.65.105
route-map nat_isp1 permit 10
match ip address 110 match interface GigabitEthernet0/1
What is wrong there ? What I have to change in order to enable access between networks?
Thank you in advance for any advice or tip.
Piotr
10 Replies 10
cadet alain
With this config you are natting your VPN traffic so it can't work , just edit your ACL like this:
ip access-list extended 110
5 deny ip 10.0.0.0 0.0.1.255 10.0.100.0 0.0.0.0.255
Alain
Unfortunately it didn't solve the problem.
Wright now ACL 110 looks as follow:
Extended IP access list 110
    5 deny ip 10.0.0.0 0.0.1.255 10.0.100.0 0.0.0.255     10 permit ip 10.0.0.0 0.0.1.255 any (4590031 matches)
Any other ideas what is wrong in my config?
How about routes? I do not see anything in my routing table, which will tell, that packets from 10.0.0.0/23 to 10.0.100.0/24 should be send via VPN:
Gateway of last resort is 213.192.65.105 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 213.192.65.105
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.0.0.0/23 is directly connected, GigabitEthernet0/0
L        10.0.0.1/32 is directly connected, GigabitEthernet0/0
      213.192.65.0/24 is variably subnetted, 3 subnets, 3 masks
S        213.192.65.0/24 [1/0] via 213.192.65.105
C        213.192.65.104/30 is directly connected, GigabitEthernet0/1
L        213.192.65.106/32 is directly connected, GigabitEthernet0/1
Here are some stuff you need to check on both sites:
1. Crypto ACL to encrypt interesting traffic in crypto map config.
HQ:
Same on Branch:
access-list 189 permit ip 10.0.100.0 0.0.0.255 10.0.0.0 0.0.1.255
2. NAT exempting on both routers for interesting traffic.
3. ISAKMP phase 1 encryption, authentication, hash, DF group must match.
4. IPSEC phase 2 also encryption, hash must match.
5. And you may need to check routing on both routers to be pointed correct IP address.
6. In crypto map peers must match pointing to each other.
Debugging:
debug crypto isakmp 7
debug crypto ipsec 7
This link may help to identify the problem:
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
can you post the output from following after pinging a remote host from a local host:
sh crypto isakmp sa
sh crypto ipsec sa
Alain
Hi guys,
@Abzal
1. On HQ router there is such ACL , on branch one - as I wrote, there is RV180 so I do not have access to console, GUI only.
2., 3. and 4. VPN connection is estableshed , see later in this post.
5. Can you elaborate little bit more?
6. They are, otherwis, as far as I know, I will not be able to establish VPN connection.
@Cadet
Here you are:
#ping 10.0.100.200
Sending 5, 100-byte ICMP Echos to 10.0.100.200, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
213.192.65.106  78.133.254.114  QM_IDLE           1005 ACTIVE
IPv6 Crypto ISAKMP SA
#sh crypto ipsec sa
interface: GigabitEthernet0/1     Crypto map tag: GLIWICE-MAP, local addr 213.192.65.106
   protected vrf: (none)    local  ident (addr/mask/prot/port): (10.0.0.0/255.255.254.0/0/0)    remote ident (addr/mask/prot/port): (10.0.100.0/255.255.255.0/0/0)    current_peer 78.133.254.114 port 500      PERMIT, flags={origin_is_acl,}     #pkts encaps: 98210, #pkts encrypt: 98210, #pkts digest: 98210     #pkts decaps: 109098, #pkts decrypt: 109098, #pkts verify: 109098     #pkts compressed: 0, #pkts decompressed: 0     #pkts not compressed: 0, #pkts compr. failed: 0     #pkts not decompressed: 0, #pkts decompress failed: 0     #send errors 0, #recv errors 0
     local crypto endpt.: 213.192.65.106, remote crypto endpt.: 78.133.254.114
     path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/1      current outbound spi: 0x3D2A55A(64136538)      PFS (Y/N): Y, DH group: group2
     inbound esp sas:
      spi: 0x742BA200(1949016576)         transform: esp-3des esp-md5-hmac ,         in use settings ={Tunnel, }         conn id: 2015, flow_id: Onboard VPN:15, sibling_flags 80000040, crypto map: GLIWICE-MAP         sa timing: remaining key lifetime (k/sec): (4302174/1959)         IV size: 8 bytes         replay detection support: Y         Status: ACTIVE(ACTIVE)
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
      spi: 0x3D2A55A(64136538)         transform: esp-3des esp-md5-hmac ,         in use settings ={Tunnel, }         conn id: 2016, flow_id: Onboard VPN:16, sibling_flags 80000040, crypto map: GLIWICE-MAP         sa timing: remaining key lifetime (k/sec): (4306937/1959)         IV size: 8 bytes         replay detection support: Y         Status: ACTIVE(ACTIVE)
     outbound ah sas:
     outbound pcp sas:
Thank you for your current support, guys!
you are pinging from the router but to test it you must ping from a host in 10.0.0.0/23
Alain
Come on...
Why is that ? Why there is no possibility to ping second network directly from router?
Just to be clear: of course, from hosts in both networks I can ping each others, so VPN is working correctly.
In addition to this topic - probably, in the future, I will have to setup second vpn site-to-site connection from HQ to new branch. Is such configuration different from my existing one or the only thing I will have to do is to repeat same steps as with one VPN ?
Thanks for your support guys, I apprieciate.
Yes, it should work. You will need to add a new static crypto map and tunnel-group for the second Branch if ISAKMP and IPSec policy can remain the same if they are the same on the new Branch. And you need to exempt subnets of new Branch and new crypto ACL.
Here is useful link with explanation:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807f9a89.shtml
Note. I assume that you will have static public on the second Branch and will use one outside interface at HQ(single-homed).
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Piotr Pawlowski a écrit:
Come on...
It won't work because this is a private IP you're pinging and traffic from the router is not going through the VPN.
Alain
Allthough its from april last year I would like to add some comments.
what Cadet Alain said is right. you are pinging from the external interface.
I am sure it will work if you do
ping 10.0.100.200 source 10.0.0.1
Or just use ping and then the extended part.
regards
Martin
