Site-to-Site VPN: Can't ping other network
shawnsherwood
I cannot ping the remote LAN, but site to site tunnel show's connected. I am able to ping from a local computer to the LAN IP on the remote ASA and vice versa for the other network.
The configuration has been done through the ASDM (I'm still a little green on the CLI)
Been struggling with this thing for hours NEED HELP, Site has to be online tomorrow
Thanks in Advance!
Local Site ASA 10.128.1.254
interface Vlan1
nameif inside
security-level 100
ip address 10.128.1.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address Safeway-Adtran 255.255.255.252
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 66.7.224.17
name-server 66.7.224.18
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
protocol-object udp
protocol-object tcp
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object ip
protocol-object udp
protocol-object tcp
access-list test_splitTunnelAcl standard permit any
access-list outside_1_cryptomap extended permit ip Safeway-Subnet 255.255.255.0 Inland-Empire-Subnet 255.255.255.0
access-list inside_nat0_outbound extended permit ip any any
access-list inside_nat0_outbound extended permit ip Safeway-Subnet 255.255.255.0 Inland-Empire-Subnet 255.255.255.0
access-list NONAT extended permit ip Inland-Empire-Subnet 255.255.255.0 Safeway-Subnet 255.255.255.0
access-list NONAT extended permit ip Safeway-Subnet 255.255.255.0 Inland-Empire-Subnet 255.255.255.0
access-list outside_access_in extended permit object-group DM_INLINE_PROTOCOL_2 any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPN_DHCP 10.128.1.60-10.128.1.69 mask 255.255.255.255
ip local pool test 10.128.1.70-10.128.1.71 mask 255.255.0.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 Adtran 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http Safeway-Subnet 255.255.255.0 inside
http Inland-Empire-Subnet 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt connection timewait
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group5
crypto map outside_map 1 set peer 64.31.115.54
crypto map outside_map 1 set transform-set ESP-AES-256-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 50
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes-256
hash sha
group 2
lifetime 86400
telnet Safeway-Subnet 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd auto_config outside
dhcpd address 10.128.1.50-10.128.1.59 inside
dhcpd dns 66.7.224.17 66.7.224.18 interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy JSP internal
group-policy JSP attributes
dns-server value 71.250.0.12 71.242.0.12
vpn-tunnel-protocol IPSec
username Brian password azfVYiIWlJ60Q23e encrypted
username Brian attributes
service-type remote-access
username ssherwood password JkjHliTRLXMXtcz8 encrypted privilege 15
username zshafiq password 1cX5kOX/dDvqoDs6 encrypted privilege 15
tunnel-group JSP type remote-access
tunnel-group JSP general-attributes
address-pool VPN_DHCP
default-group-policy JSP
tunnel-group JSP ipsec-attributes
pre-shared-key *****
tunnel-group 64.31.115.54 type ipsec-l2l
tunnel-group 64.31.115.54 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
Remote Site ASA 10.128.2.254
access-list inside_nat0_outbound extended permit ip Inland-Empire-Subnet 255.255.255.0 Safeway-Subnet 255.255.255.0
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
ip local pool VPN_DHCP 10.128.2.60-10.128.2.69 mask 255.255.255.0
ip local pool Inland 10.128.2.50-10.128.2.52 mask 255.255.0.0
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 modem 1
http server enable
crypto map outside_map 1 set peer Safeway-Adtran
encryption 3des
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 5
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
telnet 172.16.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.128.2.50-10.128.2.59 inside
dhcpd dns 64.60.0.17 interface inside
webvpn
group-policy Inland internal
group-policy Inland attributes
dns-server value 64.60.0.17
tunnel-group Inland type remote-access
tunnel-group Inland general-attributes
address-pool Inland
default-group-policy Inland
tunnel-group Inland ipsec-attributes
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
6 Replies 6
andrew.prince
Level 10
Level 10
Off the bat I notice that you do not have "sysopt connection permit-vpn" at either end which allows VPN's to bypass any ACL's applied to the outside interface, which you do have on both sites?
Shawn,
Your ACLs seems to be causing the issue. Also, on remote site I do not see the 'outside_1_cryptomap' ACL.
Which site is which end. Can you post complete configuration of both sides (remove username/snmp info) with 'no names'. That shows IP addresses and easy to t-shoot.
Thx
MS
Andrew,
That was it. Thanks, working like a charm
THANKS AGAIN
Yeap.. Thanks Andrew. I totally went in wrong  direction.5 Stars to you ..:-).
Thx
MS
Thanks for the rating
Sure no problem
