Cisco 851 router clock change problem
kshambhaskar213
Hi all,
We have around 5 remote locations which communicate with a NOC(Network Operations Center) via VSAT link.
On remote location we have Cisco 851 routers. I have tried to change the clock and date of the routers to present day.
But after some time the clock is automatically showing wrong(9th March 2002 in this case).
Kindly suggest.
Thank you in advance.
Sham
5 Replies 5
andrew.prince
Level 10
Level 10
You should consider configuring NTP to keep the time accurate.
Leo Laohoo
850 and 870 does not support NTP, however, it does support SNTP.
hi leo,
i don't have any 850s with me, but i would disagree with you on the 870s. it does support both NTP and SNTP.
877#sh ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(11)T3, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 12-Jul-07 06:58 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
877 uptime is 1 day, 18 hours, 37 minutes
System restarted at 14:37:46 SGT Thu Dec 8 2011
System image file is "flash:c870-advsecurityk9-mz.124-11.T3.bin"
877(config)#ntp ?
  access-group        Control NTP access
  authenticate        Authenticate time sources
  authentication-key  Authentication key for trusted time sources
  broadcastdelay      Estimated round-trip delay
  clock-period        Length of hardware clock tick
  logging             Enable NTP message logging
  master              Act as NTP master clock
  max-associations    Set maximum number of associations
  peer                Configure NTP peer
  server              Configure NTP server
  source              Configure interface for source address
  trusted-key         Key numbers for trusted time sources
877(config)#sntp ?
  broadcast  Configure SNTP broadcast services
  logging    Enable SNTP message logging
  multicast  Configure SNTP multicast services
  server     Configure SNTP server
You're right about the 870 supporting both.   Mea Culpa.
johnlloyd_13
Level 9
Level 9
hi sham,
you've probably used the "clock set" command on your 851. the clock info won't be retained if it's rebooted. as suggested by andrew, it's recommended to use NTP.
