site to site vpn doesn't work between fortigate and asa
pratik-koshiya
I am configuring site to site between fortigate and asa. I am not sure if I am making any mistake in configuration or not. I got information for fortigate and based on that I am implementing peer config in asa. Below is my config.
: Saved
ASA Version 9.1(1)
hostname asa-01
domain-name xyz.com
enable password vee3QRaabJe3c8XP encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
ip local pool VPNpool 10.11.1.101-10.11.1.120 mask 255.255.255.0
interface GigabitEthernet0/0
 nameif Outside
 security-level 0
 ip address X.X.X.X 255.255.255.252
interface GigabitEthernet0/1
 nameif Inside
 security-level 100
 ip address 10.11.1.1 255.255.255.0
interface GigabitEthernet0/2
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 nameif DMZ
 security-level 50
 ip address 192.168.50.1 255.255.255.0
interface Management0/0
 management-only
 nameif management
 security-level 100
banner exec ------  This is xyz Property. If you do not have permission than leave now -------
banner login ------  This is xyz Property. If you do not have permission than leave now -------
banner asdm ------  This is xyz Property. If you do not have permission than leave now -------
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns domain-lookup Outside
dns domain-lookup Inside
dns domain-lookup management
dns server-group DefaultDNS
 domain-name xyz.com
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network GENERIC_ALL
 subnet 0.0.0.0 0.0.0.0
object network Internal
 subnet 10.11.1.0 255.255.255.0
object network xyz-GRP1
 subnet 10.1.0.0 255.255.0.0
 description GRP1
object network xyz-GRP2
 subnet 10.1.1.0 255.255.255.0
 description GRP2
object network xyz-GRP3
 subnet 10.13.0.0 255.255.0.0
 description GRP3
object network xyz-GRP4
 subnet 10.1.20.0 255.255.255.0
 description GRP4
object network xyz-GRP5
 subnet 10.1.50.0 255.255.255.0
 description GRP5
object network xyz-GRP6
 subnet 10.1.25.0 255.255.255.0
 description GRP6
object network NETWORK_OBJ_10.11.1.0_24
object network DMZ
 subnet 192.168.50.0 255.255.255.0
object-group protocol TCPUDP
 protocol-object udp
 protocol-object tcp
object-group network xyz-Network
 description exclude SF
 network-object object xyz-GRP1
 network-object object xyz-GRP2
 network-object object xyz-GRP3
 network-object object xyz-GRP4
 network-object object xyz-GRP5
 network-object object xyz-GRP6
object-group service IKE udp
 description for test
 port-object eq 4500
 port-object eq isakmp
access-list Outside_cryptomap extended permit ip 10.11.1.0 255.255.255.0 object-group xyz-Network
access-list Outside_cryptomap extended permit esp any host y.y.y.y
access-list Outside_cryptomap extended permit udp any host y.y.y.y object-group IKE
access-list Outside_access_in extended permit tcp any 192.168.50.0 255.255.255.0 eq www
access-list xyz_splitTunnelAcl standard permit 10.11.1.0 255.255.255.0
access-list test extended permit ip object Internal object-group xyz-Network
pager lines 24
logging enable
logging buffered debugging
logging trap debugging
logging asdm informational
mtu Outside 1500
mtu Inside 1500
mtu management 1500
mtu DMZ 1500
ip verify reverse-path interface Outside
ip verify reverse-path interface Inside
ip verify reverse-path interface management
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (Inside,Outside) source dynamic GENERIC_ALL interface inactive
nat (Inside,Outside) source static NETWORK_OBJ_10.11.1.0_24 NETWORK_OBJ_10.11.1.0_24 destination static xyz-Network xyz-Network no-proxy-arp route-lookup
 nat (Inside,Outside) dynamic interface
access-group Outside_access_in in interface Outside
route Outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.11.1.0 255.255.255.0 Inside
http 10.11.1.0 255.255.255.0 Outside
http 192.158.1.1 255.255.255.255 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set myset esp-3des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal 3DES-MD5
 protocol esp encryption 3des
 protocol esp integrity md5
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Outside_map 1 match address Outside_cryptomap
crypto map Outside_map 1 set pfs
crypto map Outside_map 1 set peer y.y.y.y
crypto map Outside_map 1 set ikev1 transform-set myset
crypto map Outside_map 1 set ikev2 ipsec-proposal 3DES-MD5
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Outside_map interface Outside
crypto map outside_map 1 match address Outside_cryptomap
crypto ca trustpool policy
crypto ca server
 shutdown
 cdp-url http://sfasa.xyz.com/+CSCOCA+/asa_ca.crl
 issuer-name CN=sfasa.xyz.com
 smtp from-address admin@sfasa.xyz.com
crypto ikev2 policy 10
 encryption aes-192
 integrity sha
 group 5 2
 prf sha
 lifetime seconds 86400
crypto ikev2 policy 20
 encryption aes
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 30
 encryption 3des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 40
 encryption des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 50
 encryption 3des
 integrity md5
 group 2
 prf sha
crypto ikev2 enable Outside
crypto ikev1 enable Outside
crypto ikev1 policy 5
 authentication pre-share
 encryption 3des
 hash md5
 group 2
 lifetime 86400
crypto ikev1 policy 20
 authentication rsa-sig
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 30
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 40
 authentication crack
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 50
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 60
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 70
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 80
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 90
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 100
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 110
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 120
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 130
 encryption des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 140
 encryption des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 150
 encryption des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh 10.11.1.0 255.255.255.0 Inside
ssh timeout 5
console timeout 0
management-access Inside
dhcpd address 10.11.1.10-10.11.1.100 Inside
dhcpd dns 208.67.222.222 208.67.220.220 interface Inside
dhcpd domain xyz.com interface Inside
dhcpd enable Inside
dhcpd address 192.168.1.2-192.168.1.10 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy xyz internal
group-policy xyz attributes
 dns-server value 208.67.222.222 208.67.220.220
 vpn-tunnel-protocol ikev1
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value xyz_splitTunnelAcl
 default-domain value xyz.com
group-policy DfltGrpPolicy attributes
 vpn-tunnel-protocol ikev1 ikev2 ssl-clientless
group-policy GroupPolicy_y.y.y.y internal
group-policy GroupPolicy_y.y.y.y attributes
 vpn-filter value Outside_cryptomap
username user2 password ************* encrypted privilege 15
username user1 password ************* encrypted privilege 15
tunnel-group y.y.y.y type ipsec-l2l
tunnel-group y.y.y.y general-attributes
 default-group-policy GroupPolicy_y.y.y.y
tunnel-group y.y.y.y ipsec-attributes
 ikev1 pre-shared-key *****
 ikev2 remote-authentication pre-shared-key *****
 ikev2 local-authentication pre-shared-key *****
tunnel-group xyz type remote-access
tunnel-group xyz general-attributes
 address-pool VPNpool
 default-group-policy xyz
tunnel-group xyz ipsec-attributes
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect pptp
 class class-default
  user-statistics accounting
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:a8e7ae05ef9efeb570c96ae8339620a0
: end
Can anyone suggest me any change or re-direct me for what to check on asa side?
10 Replies 10
Robert Falconer
Have you run any debugs when trying to make the connection?
I've had issues with PFS on tunnels between vendors. Have you tried disabling PFS on both ends?
pratik-koshiya
Apr 17 2014
10:06:28
752015
Tunnel Manager has failed to establish an L2L SA.  All configured IKE versions failed to establish the tunnel. Map Tag= Outside_map.  Map Sequence Number = 1.
Apr 17 2014
10:06:28
752012
IKEv1 was unsuccessful at setting up a tunnel.  Map Tag = Outside_map.  Map Sequence Number = 1.
Apr 17 2014
10:05:56
752014
Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1 after a failed attempt..  Map Tag = Outside_map.  Map Sequence Number = 1.
Apr 17 2014
10:05:56
752012
IKEv2 was unsuccessful at setting up a tunnel.  Map Tag = Outside_map.  Map Sequence Number = 1.
Apr 17 2014
10:05:56
750003
Local:x.x.x.x:500 Remote:y.y.y.y:500 Username:y.y.y.y Negotiation aborted due to ERROR: Maximum number of retransmissions reached
Do you have any other tunnels configured on this ASA? You have a lot of parameters defined for transform sets, authentication types, hash and encryption.
What did the Fortigate admin provide you?
PFS is currently causing me issues between vendors. You have PFS configured everywhere which could be causing a problem.
Yes I have another remote IPSec tunnel configured on ASA through which I am accessing ASA remotely.  Yes we have PFS configured on both side with group 2. Fortigate admin has provided me peer ip, phase1 and phase2 config with PSK and PFS that we used.
It looks like you are encountering the problem in the ISAKMP phase 1 negotiation. I would start by re-configuring the shared key (and probably ask the administrator of the fortigate to do the same. If it still does not work then I would try running debug for isakmp on your side and see if it tells you a bit more about where the problem is.
Rick
Rick
I am setting up site to site again. I will update once i configured it.
New problem arise after i removed tunnel and choose internal DNS. I saw that tunnel comes up from both ends. I can ping IP but i cannot use any internal services or RDP services. Can you tell me which ACL i should implement now?
I have already allow ACL for IP service between both ends.
: Saved
ASA Version 9.1(1)
hostname sfasa-01
domain-name xyz.com
names
 nameif Outside
 security-level 0
 ip address x.x.x.x 255.255.255.252
 nameif Inside
 security-level 100
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 nameif DMZ
 security-level 50
 ip address b.b.b.b 255.255.255.0
 management-only
 nameif management
 security-level 100
banner exec ------  This is xyz Inc Property. If you do not have permission than leave now -------
banner login ------  This is xyz Inc Property. If you do not have permission than leave now -------
banner asdm ------  This is xyz Inc Property. If you do not have permission than leave now -------
ftp mode passive
 domain-name xyz.com
 description GRP2
 description GRP3
 description GRP4
 description GRP5
 description GRP6
object network outside_gateway
 host a.a.a.a
 protocol-object udp
 protocol-object tcp
 port-object eq 4500
access-list Outside_access_in extended permit tcp any 172.16.10.0 255.255.255.0 eq www
access-list Outside_access_in_1 extended permit icmp any any
pager lines 24
logging enable
mtu Outside 1500
mtu Inside 1500
mtu DMZ 1500
mtu management 1500
no failover
icmp unreachable rate-limit 10 burst-size 5
arp timeout 14400
access-group Outside_access_in_1 in interface Outside
route Outside 0.0.0.0 0.0.0.0 a.a.a.a 1
http server enable
crypto map Outside_map 1 set reverse-route
crypto ca server
 shutdown
 encryption aes-192
 integrity sha
 group 5 2
 prf sha
 encryption aes
 integrity sha
 group 5 2
 prf sha
 encryption 3des
 integrity sha
 group 5 2
 prf sha
 encryption des
 integrity sha
 group 5 2
 prf sha
 encryption 3des
 integrity md5
 group 2
 prf md5
 encryption 3des
 hash md5
 group 2
 lifetime 86400
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
 encryption aes
 hash sha
 group 2
 lifetime 86400
 encryption aes
 hash sha
 group 2
 lifetime 86400
 encryption aes
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 86400
 encryption des
 hash sha
 group 2
 lifetime 86400
 encryption des
 hash sha
 group 2
 lifetime 86400
 encryption des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 10.13.1.5 10.1.1.5 interface Inside
dhcpd enable Inside
dhcpd address b.b.b.a-b.b.b.z DMZ
dhcpd dns 208.67.222.222 208.67.220.220 interface DMZ
dhcpd enable DMZ
username user2 password ********* encrypted privilege 15
username user1 password ********* encrypted privilege 15
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect pptp
  inspect icmp error
 class class-default
  set connection decrement-ttl
Cryptochecksum:674e06895c717bd8d6a13a1d25c2cfb9
: end
What is the policy on the Fortigate? You don't seem to have any filtering on the ASA.
for fotigate it is
config firewall address
    edit "all"
    next
    edit “asa Subnet"
        set associated-interface “asaport”
        set subnet 10.11.1.0 255.255.255.0
   next
end
config vpn ipsec phase1
edit “asa”
        set interface "asaport"
        set dhgrp 2
        set proposal 3des-md5
        set remote-gw x.x.x.x
        set psksecret ENC *******
    next
config vpn ipsec phase2
       edit “asa 10.1.20.0/24"
        set phase1name “asa”
        set dhgrp 2
        set dst-subnet 10.11.1.0 255.255.255.0
        set keylifeseconds 3600
        set src-subnet 10.1.20.0 255.255.255.0
    next
    edit “asa 10.1.25.0/24"
        set dhgrp 2
        set src-subnet 10.1.25.0 255.255.255.0
    next
    edit "asa 10.1.50.0/24"
        set phase1name "asa"
        set dhgrp 2
        set src-subnet 10.1.50.0 255.255.255.0
    next
    edit "asa 10.13.0.0/16"
        set dhgrp 2
        set src-subnet 10.13.0.0 255.255.0.0
    next
    edit "asa 10.1.1.0/24"
        set dhgrp 2
        set src-subnet 10.1.1.0 255.255.255.0
    next
end
config firewall policy
edit 40
        set srcintf "SrvToExtern1"
        set dstintf "asaport"
            set srcaddr "all"
            set dstaddr "asa Subnet"
        set action ipsec
        set schedule "always"
            set service "ANY"
        set inbound enable
        set outbound enable
        set vpntunnel "asa"
    next
    edit 41
        set srcintf "IntToExtern1"
            set srcaddr "all"
        set action ipsec
            set service "ANY"
        set inbound enable
        set outbound enable
        set vpntunnel "asa"
    next
    edit 42
        set srcintf "DMZToExtern1"
            set srcaddr "all"
        set action ipsec
            set service "ANY"
        set inbound enable
        set outbound enable
        set vpntunnel "asa"
    next
end
I saw one more thing here. While on vpn, I can not ping any internal address. When i try to use any http service from remote network, it directly resolve to opendns serach website. should i just inherit DNS in vpn policy or should I just change it to our standard internal DNS address that we are using for all site. I can see DNS address belongs to OpenDNS.
pratik-koshiya
Hey, so tunnel is up on both side. I think i has misconfigured from my side and peer ip address was wrong on other side as it was setup as gateway. I found one more problem here.
I can access all the services from office 2 to office 1. but i can not ping or access any machine from office 1 to office 2. any thoughts about where i should look for issue?
