site to site with same nside IPI
vatrix828749
I am attempting to connect my Cisco 515E to a site to site VPN. The IP on the other side has the same IP # as my PIX. Will this be a problem?
sachinraja
Level 9
Level 9
YEAH . it will be a problem. You cannot have overlapping IP addresses on a site-to-site VPN. Your crypto ACLs cannot be defined if you have overlapping IP addresses. NAT the traffic at one end (preferably the destination) and then encrypt your traffic on the IPSEC.
Doing this, you can communicate between the LANs successfully. Hope this helps. rate replies if found useful. Let us know if you need more assistance on this.
Raj
sachinraja
Level 9
Level 9
oops. did i read the question wrong !!! if you have the PIX inside IP same at both the ends, i dont think you will have any issues. its the remote LAN subnet that matters the most here. PIX inside is anyway local to the locations, and does not come into picture for IPSEC connections.
Raj
