SLA failover from one ISP to another in a separate VRF
Drew T
I have a single 3945 which has 2 x Fibre providers terminating onto it (say Gi0/1 and Gi0/2). There are multiple VLAN's and subnets on the router, one of which is solely dedicated to Gi0/2. Gi0/2 lives in a VRF with its own DHCP/NAT/Crypto maps (and a single VLAN dot1q sub interface). Both providers are statically routed to via a default route, and there is no option for BGP here nor any other dynamic routing protocol (they are totally different ISP's).
They were put on the same device after being migrated from two individual routers, and at the request of the client, they wanted one to be ISP to be totally segregated for their own discrete/private use (Gi0/2).
They've now requested they'd like either link to failover to the other, in the event of an outage. They're not fussed if their VPN fails, so long as internet connectivity is maintained in some form.
Is there an easy way to failover from a Gi0/1 in no VRF to Gi0/2 in a VRF (or vice versa)? I could potentially place Gi0/1 into another VRF if required, but it seems excessive.
After advice on the best way to do this, and any possible configuration suggestions/examples.
Thanks!
7 Replies 7
an IP SLA and a track failover will probably work. Post the configuration you have on your router so far, so we can fill in the missing bits and pieces...
Thanks George, sorry this took a while as the router has a huge amount of config on it I had to sanitise.
Building configuration...
hostname router1
boot-start-marker
boot-end-marker
vrf definition GeneralVRF
 rd 192.168.10.0:666
 address-family ipv4
 exit-address-family
logging buffered 51200
no aaa new-model
memory-size iomem 10
ip cef
no ip dhcp conflict logging
ip dhcp excluded-address 10.0.0.210 10.0.0.246
ip dhcp excluded-address 10.0.0.248 10.0.0.254
ip dhcp excluded-address 10.0.0.1 10.0.0.20
ip dhcp excluded-address vrf GeneralVRF 192.168.10.15
ip dhcp excluded-address vrf GeneralVRF 192.168.10.2
ip dhcp excluded-address vrf GeneralVRF 192.168.10.25
ip dhcp excluded-address vrf GeneralVRF 192.168.10.20
ip dhcp pool work_VLAN_50
 vrf GeneralVRF
 network 192.168.10.0 255.255.254.0
 default-router 192.168.10.1
 domain-name workdomainname.com.au
 dns-server 8.8.8.8 8.8.4.4
ip dhcp pool master_10
 network 10.0.0.0 255.255.255.0
 default-router 10.0.0.254
 domain-name host.com
 dns-server 10.0.0.3 8.8.8.8
 lease 0 1
ip domain name workdomainname.com.au
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
voice-card 0
hw-module sm 2
archive
 log config
  logging enable
  notify syslog contenttype plaintext
 path flash:backups
redundancy
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh source-interface GigabitEthernet0/0.10
crypto isakmp policy 1
 encr 3des
 hash sha256
 authentication pre-share
 group 2
crypto isakmp policy 2
 encr 3des
 hash sha256
 group 5
 lifetime 3600
crypto isakmp policy 10
 encr aes
 hash sha256
 group 5
 lifetime 14400
crypto isakmp key <redacted> address x.x.x.x
crypto isakmp key <redacted> address y.y.y.y
crypto isakmp key <redacted> address z.z.z.z
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set VPN-TRANS esp-3des esp-md5-hmac
 mode tunnel
crypto map inter-office-vpn 10 ipsec-isakmp
 description VPN to SITE1
 set peer x.x.x.x
 set transform-set VPN-TRANS
 match address 123
crypto map inter-office-vpn 20 ipsec-isakmp
 description VPN to SITE2
 set peer y.y.y.y
 match address 120
crypto map inter-office-vpn 30 ipsec-isakmp
 description VPN to SITE3
 set peer z.z.z.z
 match address 122
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 no ip address
 load-interval 30
 duplex auto
 speed auto
 description master Internal
 encapsulation dot1Q 10
 ip address 10.0.0.254 255.255.255.0
 ip nat inside
 no ip virtual-reassembly in
interface GigabitEthernet0/0.50
 description work
 encapsulation dot1Q 50
 vrf forwarding GeneralVRF
 ip address 192.168.10.1 255.255.254.0
 ip nat inside
interface GigabitEthernet0/1
 description General Internet
 ip address a.a.a.a 255.255.255.252
 ip nat outside
 load-interval 30
 media-type sfp
interface GigabitEthernet0/2
 description Private Internet
 ip address b.b.b.b 255.255.255.252
 ip nat outside
 load-interval 30
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source static tcp 10.0.0.4 122 interface GigabitEthernet0/2 122
ip nat inside source static tcp 10.0.0.4 443 interface GigabitEthernet0/2 443
ip nat inside source list from-master-networks interface GigabitEthernet0/2 overload
ip nat inside source list from-internal-networks interface GigabitEthernet0/2 overload
ip nat inside source list from-internal-networks interface GigabitEthernet0/1 vrf GeneralVRF overload
ip nat inside source static tcp 10.0.0.205 591 b.b.b.b 333 route-map no-nat-ipsec extendable
ip nat inside source static tcp 192.168.10.218 50001 a.a.a.a 444 vrf GeneralVRF extendable
ip route 0.0.0.0 0.0.0.0 b.b.b.c
ip route vrf GeneralVRF 0.0.0.0 0.0.0.0 a.a.a.b
ip access-list extended deny_nat_172_16
 permit ip host 10.0.0.205 10.0.0.0 0.0.255.255
ip access-list extended from-master-networks
 deny   ip 10.0.0.0 0.0.0.255 10.0.48.0 0.0.0.255
 deny   ip 10.0.0.0 0.0.0.255 10.0.16.0 0.0.0.255
 deny   ip 10.0.0.0 0.0.0.255 10.0.80.0 0.0.0.255
 permit ip 10.0.0.0 0.0.0.255 any
 permit ip 192.168.0.0 0.0.1.255 any
ip access-list extended from-internal-networks
 permit ip 192.168.2.0 0.0.1.255 any
 permit ip 192.168.10.0 0.0.1.255 any
 permit ip 10.0.1.0 0.0.0.255 any
ip access-list extended permit_any
 permit ip any any
logging trap debugging
logging origin-id hostname
logging facility syslog
logging host 103.13.186.97
logging host 150.107.73.147
access-list 120 permit ip 10.0.0.0 0.0.0.255 10.0.16.0 0.0.0.255
access-list 122 permit ip 10.0.0.0 0.0.0.255 10.0.80.0 0.0.0.255
access-list 123 permit ip 10.0.0.0 0.0.0.255 10.0.48.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
route-map no-nat-ipsec deny 10
 match ip address deny_nat_172_16
route-map no-nat-ipsec permit 20
 match ip address permit_any
end
i've had to remove a lot of the config, but it's working fine 'as is' so anything missing is a typo in the clean up.
Gi0/1 is a.a.a.a/30, with a.a.a.b being the next hop/default gateway
Gi0/2 is b.b.b.b/30, with b.b.b.c being the next hop/default gateway
The VRF and non-VRF setup both have their own DHCP pools and NAT statements (There are a lot of NAT statements i've removed from this example though).
Thanks again.
I need to lab this. Since you need both links up at the same time, with mutual failover, a simple SLA with tracking will not be enough.
I'll get back with you...
Appreciate it! If you need more info, feel free to drop me a message. As a standalone setup it works great for making it two separate services, but trying to failover one link to another i'm not so sure of.
I am working on it, will get back with you asap...
below is what I have come up with. It involves a series of EEM scripts that change the configuration of the router based on the status of the interfaces. Since figuring this out required a lot of cutting and pasting, check or better, test, before implementing:
track 1 ip sla 1 reachability
track 2 ip sla 2 reachabiity
ip sla 1
icmp-echo 8.8.8.8 source interface GigabitEthernet0/1
frequency 300
ip sla 2
icmp-echo 8.8.8.8 source interface GigabitEthernet0/2
frequency 300
ip sla schedule 1 life forever start-time now
ip sla schedule 2 life forever start-time now
event manager applet CLEAR_NAT_GeneralVRF
event track 1 state any
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat translation *"
action 3.0 cli command "end"
event manager applet CLEAR_NAT_PRIVATE_INTERNET
event track 2 state any
event manager applet GeneralVRF_DOWN
event track 1 state down
action 2.0 cli command "config t"
action 3.0 cli command "no ip route vrf GeneralVRF 0.0.0.0 0.0.0.0 a.a.a.b"
action 4.0 cli command "ip route vrf GeneralVRF 0.0.0.0 0.0.0.0 b.b.b.c"
action 5.0 cli command"no ip nat inside source list from-internal-networks interface GigabitEthernet0/1 vrf GeneralVRF overload"
action 6.0 cli command "no ip nat inside source static tcp 192.168.10.218 50001 a.a.a.a 444 vrf GeneralVRF extendable"
action 7.0 cli command "ip nat inside source list from-internal-networks interface GigabitEthernet0/1 vrf GeneralVRF overload"
action 8.0 cli command "ip nat inside source static tcp 192.168.10.218 50001 b.b.b.b 444 extendable"
action 9.0 cli command "end"
action 10.0 cli command "clear ip route vrf GeneralVRF *"
event manager applet GeneralVRF_UP
event track 1 state up
action 3.0 cli command "no ip route vrf GeneralVRF 0.0.0.0 0.0.0.0 b.b.b.c"
action 4.0 cli command "ip route vrf GeneralVRF 0.0.0.0 0.0.0.0 a.a.a.b"
action 5.0 cli command "no ip nat inside source list from-internal-networks interface GigabitEthernet0/1 vrf GeneralVRF overload"
action 6.0 cli command "no ip nat inside source static tcp 192.168.10.218 50001 b.b.b.b 444 extendable"
action 7.0 cli command"ip nat inside source list from-internal-networks interface GigabitEthernet0/1 vrf GeneralVRF overload"
action 8.0 cli command "ip nat inside source static tcp 192.168.10.218 50001 a.a.a.a 444 vrf GeneralVRF extendable"
event manager applet PRIVATE_INTERNET_DOWN
event track 2 state down
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 b.b.b.c"
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 a.a.a.b"
action 5.0 cli command "no ip nat inside source static tcp 10.0.0.4 122 interface GigabitEthernet0/2 122"
action 6.0 cli command "no ip nat inside source static tcp 10.0.0.4 443 interface GigabitEthernet0/2 443"
action 7.0 cli command "no ip nat inside source list from-master-networks interface GigabitEthernet0/2 overload"
action 8.0 cli command "no ip nat inside source list from-internal-networks interface GigabitEthernet0/2 overload"
action 9.0 cli command "no ip nat inside source static tcp 10.0.0.205 591 b.b.b.b 333 route-map no-nat-ipsec extendable"
action 10.0 cli command "ip nat inside source static tcp 10.0.0.4 122 interface GigabitEthernet0/1 vrf GeneralVRF 122"
action 11.0 cli command "ip nat inside source static tcp 10.0.0.4 443 interface GigabitEthernet0/1 vrf GeneralVRF 443"
action 12.0 cli command "ip nat inside source list from-master-networks interface GigabitEthernet0/1 vrf GeneralVRF overload"
action 13.0 cli command "ip nat inside source list from-internal-networks interface GigabitEthernet0/1 vrf GeneralVRF overload"
action 14.0 cli command "ip nat inside source static tcp 10.0.0.205 591 a.a.a.a 333 route-map no-nat-ipsec extendable"
action 15.0 cli command "end"
action 16.0 cli command "clear ip route *"
event manager applet PRIVATE_INTERNET_UP
event track 2 state up
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 a.a.a.b"
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 b.b.b.c"
action 5.0 cli command "ip nat inside source static tcp 10.0.0.4 122 interface GigabitEthernet0/1 vrf GeneralVRF 122"
action 6.0 cli command "no ip nat inside source static tcp 10.0.0.4 443 interface GigabitEthernet0/1 vrf GeneralVRF 443"
action 7.0 cli command "no ip nat inside source list from-master-networks interface GigabitEthernet0/1 vrf GeneralVRF overload"
action 8.0 cli command "no ip nat inside source list from-internal-networks interface GigabitEthernet0/1 vrf GeneralVRF overload"
action 9.0 cli command "no ip nat inside source static tcp 10.0.0.205 591 a.a.a.a 333 route-map no-nat-ipsec extendable"
action 10.0 cli command "ip nat inside source static tcp 10.0.0.4 122 interface GigabitEthernet0/2 122"
action 11.0 cli command "ip nat inside source static tcp 10.0.0.4 443 interface GigabitEthernet0/2 443"
action 12.0 cli command "ip nat inside source list from-master-networks interface GigabitEthernet0/2 overload"
action 13.0 cli command "ip nat inside source list from-internal-networks interface GigabitEthernet0/2 overload"
action 14.0 cli command "ip nat inside source static tcp 10.0.0.205 591 b.b.b.b 333 route-map no-nat-ipsec extendable"
Deepak Kumar
Please share the running-config. SLA will work
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
