SLA ICMP-echo failure even though router can ping IP
jasonww04
I'm using 64.x.x.1 as my ICMP-echo target for an SLA. The best it can do is get two replies in a row before failing. While the SLA is active, I can send 10000 pings to the same target and not lose a single one.
WTF is wrong?
track 1 ip sla 1 reachability
delay down 60 up 40
interface GigabitEthernet0/0
description LAN
ip address 172.18.8.2 255.255.255.0
ip nat inside
ip virtual-reassembly in
standby delay minimum 30 reload 60
standby version 2
standby 1 ip 172.18.8.1
standby 1 priority 115
standby 1 preempt
duplex full
speed 1000
interface GigabitEthernet0/0.19
description Facility
encapsulation dot1Q 19
ip address 172.19.8.3 255.255.255.0
ip nat inside
standby version 2
standby 2 ip 172.19.8.1
standby 2 priority 115
standby 2 preempt
interface GigabitEthernet0/0.20
description Guest
encapsulation dot1Q 20
ip address 172.20.8.3 255.255.255.0
ip nat inside
rate-limit input 1024000 192000 384000 conform-action transmit exceed-action drop
standby version 2
standby 3 ip 172.20.8.1
standby 3 priority 115
standby 3 preempt
interface GigabitEthernet0/0.23
description WAPs
encapsulation dot1Q 23
ip address 172.23.8.3 255.255.255.0
standby version 2
standby 4 ip 172.23.8.1
standby 4 priority 115
standby 4 preempt
interface GigabitEthernet0/1
ip address 10.255.255.42 255.255.255.252
ip nat outside
duplex auto
speed auto
no cdp enable
crypto map VPN
router bgp 65212
bgp log-neighbor-changes
network 172.18.8.0 mask 255.255.255.0
network 172.19.8.0 mask 255.255.255.0
network 172.20.8.0 mask 255.255.255.0
neighbor 10.255.255.41 remote-as 65112
neighbor 10.255.255.41 description Windstream Managed Router
neighbor 10.255.255.41 allowas-in
neighbor 10.255.255.41 prefix-list bgp-adv out
ip forward-protocol nd
ip nat inside source route-map NAT-rm interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 172.18.8.3
ip route 10.11.0.0 255.255.0.0 10.255.255.41
ip route 10.15.1.0 255.255.255.0 10.255.255.41
ip route 10.61.0.0 255.255.0.0 172.18.8.3
ip route 64.x.x.1 255.255.255.255 172.18.8.3
ip access-list extended NAT-ACL
deny   ip 172.18.8.0 0.0.0.255 10.11.0.0 0.0.255.255
deny   ip 172.18.8.0 0.0.0.255 10.15.1.0 0.0.0.255
deny   ip 172.18.8.0 0.0.0.255 10.61.0.0 0.0.255.255
permit ip 172.18.8.0 0.0.0.255 any
permit ip 172.19.8.0 0.0.0.255 any
permit ip 172.20.8.0 0.0.0.255 any
ip prefix-list bgp-adv seq 1 permit 172.18.8.0/24
ip prefix-list bgp-adv seq 2 permit 172.19.8.0/24
ip prefix-list bgp-adv seq 3 permit 172.20.8.0/24
ip sla auto discovery
ip sla 1
icmp-echo 64.x.x.1 source-interface GigabitEthernet0/0
frequency 20
ip sla schedule 1 life forever start-time now
route-map NAT-rm permit 10
match ip address NAT-ACL
JohnTylerPearce
Level 7
Level 7
Jason,
When you do your pings that work 10000 times are you using gi0/0 are your source interface for the pings?
Also can you post the results from
'show ip sla auto discovery' ?
Yes, I do source from g0/0:
cao-nj_hami1#ping 64.x.x.1 sou g0/0 repeat 10000
Sending 10000, 100-byte ICMP Echos to 64.106.227.1, timeout is 2 seconds:
Packet sent with a source address of 172.18.8.2
Success rate is 100 percent (10000/10000), round-trip min/avg/max = 12/14/108 ms
cao-nj_hami1#sh ip sla auto discovery
IP SLAs auto-discovery status: Enabled
The following Endpoint-list are configured to auto-discovery:
cao-nj_hami1#
cao-nj_hami1#sh ip sla stat
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
        Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: 16:42:06 EST Wed Feb 12 2014
Latest operation return code: Timeout
Number of successes: 45
Number of failures: 18
Operation time to live: Forever
cao-nj_hami1#sh track 1
Track 1
  IP SLA 1 reachability
  Reachability is Up
    118 changes, last change 00:06:21
  Delay up 40 secs, down 60 secs
  Latest operation return code: OK
  Latest RTT (millisecs) 120
This happens to me quite often as well and can be extremely frustrating. What usually happens to me is that after a while of having configured icmp-echo (2-3 months), either one or two of my SLAs randomly timeout. To fix it I stop and start the SLA schedule or I reconfigure the SLA to ping a different destination. The issue must be that I'm pinging public servers such as 8.8.8.8 or 8.8.4.4. After a while Google is probably blocking or rate limiting the pings. By changing the icmp-echo destination address to a server or device that is owned by you or someone you know that doesn't rate limit should fix the issue.
