SLA on 3725 router
Gerard Gacusan
code version is 12.3 (25)
ip sla command is not available? running in 3725 router version 12.3.
thanks
purohit_810
Level 5
Level 5
There are these three commands available:
ip slb dfp (12.3)
ip slb serverfarm (12.3)
ip slb vserver (12.3)
SLA is not available.
IP SLA commands available in:
Release
Modification
12.4(4)T
This command was introduced. This command replaces the ip sla monitor command.
12.0(32)SY
This command was integrated into Cisco IOS Release 12.0(32)SY.
12.2(33)SRB
This command was integrated into Cisco IOS Release 12.2(33)SRB. This command replaces the rtr command.
12.2(33)SRC
Support for IPv6 addresses was added.
Dharmesh Purohit
a.alekseev
Level 7
Level 7
I think you have old version of the "ip sla" command
try to find "rtr ?"
[Pls RATE if HELPS]
