Slip Errors on T1 Controller for voice
bgandhi
We have a "dry pipe" between 2 of our remote locations.
We have a dual controller T1 card: WIC card on a 2811, as below.
Multi-Flex Trunk (Drop&Insert) WAN daughter card.
FRU Part Number VWIC-2MFT-T1-DI
We brought this router online to replace 3810, just yesterday.
We are seeing slips on the Voice T1.
We changed the clocing on the controller to "internal".
Slips are still incrementing, how can I overcome that.
Configuration is attached.
bgandhi
cisco8#sh ip int brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 X.X.X.X YES NVRAM up up
FastEthernet0/1 unassigned YES NVRAM administratively down down
Serial0/0/0:1 unassigned YES NVRAM up up
Serial0/0/0:1.1 X.X.X.X YES NVRAM up up
Tunnel1 unassigned YES unset up down
__________________________________________
cisco8#sh running-config
Building configuration...
Current configuration : 6441 bytes
version 12.4
service timestamps log datetime localtime
service password-encryption
hostname cisco8
boot-start-marker
boot system flash c2800nm-ipvoice-mz.124-15.XZ.bin
boot-end-marker
logging message-counter syslog
logging buffered 4096 notifications
enable password 7 01320B070F5B565F
clock timezone EST -5
clock summer-time EDT recurring
network-clock-participate wic 0
ip cef
frame-relay switching
voice vad-time 4000
voice-card 0
no dspfarm
archive
log config
hidekeys
controller T1 0/0/0
framing esf
clock source internal
linecode b8zs
channel-group 1 timeslots 1-17
tdm-group 2 timeslots 18-24
description DNLK PNL 2 PORT 4 BRCISCO1
controller T1 0/0/1
framing esf
linecode b8zs
ds0-group 1 timeslots 1 type e&m-wink-start
ds0-group 2 timeslots 2 type e&m-wink-start
ds0-group 3 timeslots 3 type e&m-wink-start
ds0-group 4 timeslots 4 type e&m-wink-start
ds0-group 5 timeslots 5 type e&m-wink-start
ds0-group 6 timeslots 6 type e&m-wink-start
ds0-group 7 timeslots 7 type e&m-wink-start
ds0-group 8 timeslots 8 type e&m-wink-start
ds0-group 9 timeslots 9 type e&m-wink-start
ds0-group 10 timeslots 10 type e&m-wink-start
ds0-group 11 timeslots 11 type e&m-wink-start
ds0-group 12 timeslots 12 type e&m-wink-start
ds0-group 13 timeslots 13 type e&m-wink-start
ds0-group 14 timeslots 14 type e&m-wink-start
ds0-group 15 timeslots 15 type e&m-wink-start
ds0-group 16 timeslots 16 type e&m-wink-start
ds0-group 17 timeslots 17 type e&m-wink-start
tdm-group 0 timeslots 18-24
description UPLK PNL 1 PORT 6 PBX LOOP 47
interface Tunnel1
no ip address
interface FastEthernet0/0
description UPLK CMPSWITCH12 0/9
ip address x.x.x.x 255.255.255.192
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:1
description *** Direct link to Bristol DC ***
bandwidth 1536
no ip address
encapsulation frame-relay
frame-relay traffic-shaping
frame-relay intf-type dce
interface Serial0/0/0:1.1 point-to-point
ip address x.x.x.x 255.255.255.252
snmp trap link-status
frame-relay interface-dlci 1005
class frf12
vofr cisco
map-class frame-relay frf12
frame-relay cir 1088000
frame-relay bc 1000
frame-relay voice bandwidth 170000
frame-relay fragment 1600
frame-relay fair-queue
access-list 10 permit 0.0.0.0
snmp-server engineID local 00000009020000107B90CD8A
snmp-server community public RO
snmp-server community secret RW
snmp-server enable traps tty
snmp-server host 164.153.11.13 secret frame-relay snmp
connect tdm T1 0/0/0 2 T1 0/0/1 0
Two situations:
We're the clock master ( normally if we're connected to another PBX):
controller t1 0/0/0
We're the clock slave ( if we're connected to a provider, or a PBX that feeds us the clock):
network-clock-select 1 t1 0/0/0
controller t1 0/0/0
clock source line
Try adding the network-clock-select (global config) command for this T1.
