SLM 2048 - Can't connect to web based utility
mattrat890
Out of the box SLM 2048, connected 1 PC and our Linksys BEFSR41 Router, powered it up and tried to access the web based utility. It gives me this:
Connection Interrupted
The connection to the server was reset while the page was loading.
The network link was interrupted while negotiating a connection. Please try again.
Any ideas? We have a static IP and the router IP address has been changed from the default to 10.0.0.1
drolemc
Level 6
Level 6
It is a browser problem. If you are using Mozilla or IE then you will get this error. If you have installed any plugins then uninstall it.
Disable the proxy and firewalls to solve this error. Then try.
