Slow internet speeds through 7301 router.
cswallace1
Hi all.   I just upgraded to Gig speeds through comcast. I am getting high 800s from modem straight to pc but low 200Mbps once I go through the router.  Not sure if the router can handle the throughput but could not find anything on it.  My question:  is there anything that I can configure on the router to increase the speeds or do I have to get a newer router??   My running config is below.  Thanks in advance.
Building configuration...
Current configuration : 1719 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot system flash:c7301-a3jk9s-mz.124-23.bin
boot-end-marker
enable secret 5 $1$7Hi6$LIodE/TUYuZHbnuUcFJp5/
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.60
ip dhcp excluded-address 192.168.1.1 192.168.1.60
ip dhcp pool data
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 4.2.2.2 4.2.2.1 8.8.8.8 8.8.4.4
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
no routing dynamic
interface GigabitEthernet0/1
ip nat inside
no ip route-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/2
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
media-type rj45
no negotiation auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.1.6 81 interface GigabitEthernet0/0 81
access-list 1 permit any
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
your 7301 is (obviously) an ancient device running outdated software, but nevertheless should be able to achieve a WAN throughput of +/- 1Gbit. You could make a few changes (marked in bold), but also post the output of:
sh interfaces GigabitEthernet0/0
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool data
import all
ip address dhcp
ip nat outside
--> ip route-cache cef
--> ip route-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
no routing dynamic
ip nat inside
--> ip route-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
media-type rj45
no negotiation auto
no ip http server
--> access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input all
end
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool data
import all
ip address dhcp
ip nat outside
--> ip route-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
no routing dynamic
ip nat inside
--> ip route-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
media-type rj45
no negotiation auto
no ip http server
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input all
end
Thank you for the quick response Georg.   I updated the Bold print and my speeds are now matching what I was getting without the router!!!
