Slow Internet Using 2621XM
shaun.cooney
Hi everyone,
I have recently switched my cable internet connection over to a Cisco C2621XM replacing my old Netgear ISP provided router. Before the switch my internet was lightning speed. When I clicked "Home" or entered a URL I would have the site fully loaded in a second or two but now it's taking around 8-10 seconds to do the same thing. Maybe this isn't particually slow but it gets somewhat frustrating as i'm sure you will understand.
My current setup is ---[cable modem]---[2621xm]---[switch]---
To confirm that this wasn't a switch issue I have tried several switches including a Cisco 3500 series and several off the shelf ISRs including a Netgear and a D-Link all with no avail.
The memory and CPU never go above 30%.
My config is below. Any help is greatly appreciated!
Cheers!
Shaun
ip inspect log drop-pkt
ip inspect max-incomplete low 100
ip inspect max-incomplete high 1100
ip inspect one-minute low 100
ip inspect one-minute high 1100
ip inspect udp idle-time 15
ip inspect dns-timeout 2
ip inspect tcp idle-time 600
ip inspect tcp synwait-time 10
ip inspect name CBAC-IN-OUT ftp
ip inspect name CBAC-IN-OUT http
ip inspect name CBAC-IN-OUT rtsp
ip inspect name CBAC-IN-OUT tcp
ip inspect name CBAC-IN-OUT udp
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
description #### TO INTERNET ####
ip address dhcp
ip access-group FIREWALL in
no ip redirects
no ip proxy-arp
ip nat outside
ip inspect CBAC-IN-OUT out
no ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
description #### TO LAN ###
ip address 10.1.1.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip nat inside source list ACL_NAT_ADDRESSES interface FastEthernet0/0 overload
ip access-list standard  ACL_NAT_ADDRESSES
  permit ip 10.0.0.0 0.255.255.255
router#show int f0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is AmdFE, address is 0011.bb22.5b20 (bia 0011.bb22.5b20)
  Description: ### TO INTERNET ###
  Internet address is x.x.x.x
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:15, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 55000 bits/sec, 3 packets/sec
  5 minute output rate 3000 bits/sec, 4 packets/sec
     1727555 packets input, 871612830 bytes
     Received 611 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     1108027 packets output, 189986330 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     0 babbles, 0 late collision, 5 deferred
     4 lost carrier, 0 no carrier
router#show int f0/1
FastEthernet0/1 is up, line protocol is up
  Hardware is AmdFE, address is 0011.bb22.5b21 (bia 0011.bb22.5b21)
  Description: ### TO LAN ###
  Internet address is 10.1.1.1/24
  Last input 00:00:05, output 00:00:00, output hang never
  5 minute input rate 2000 bits/sec, 2 packets/sec
  5 minute output rate 43000 bits/sec, 3 packets/sec
     1101009 packets input, 191160371 bytes
     Received 639 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     1699094 packets output, 865312348 bytes, 0 underruns
     0 output errors, 2 collisions, 2 interface resets
     1 lost carrier, 0 no carrier
Brandon Lynch
Hey Shaun,
Just to clarify, your previous setup was as follows, correct? -
Modem -- Netgear router -- Switch -- Users
Have you tried connecting directly into the 2621XM to test the internet speed and if so, what did you find?  Also, if you remove 'ip inspect' and/or the ACLs from these interfaces, does the problem clear?
Brandon
Hi Brandon,
Thanksd for your reply. Yes you are correct, that was my previous setup although the Netgear router acted as both a router and a switch for a while until I needed more capacity.
I am currently plugged directly into the Router using an x-over cable. I have (quickly) removed all ACLs and disabled CBAC. It seems that this doesn't affect anything. The speed is still slow.
Any other thoughts?
Shaun
