Slow performace on Cisco 1921 Router
a17ha9001
I need assistance with our Cisco 1921 router, the performance is extremely slow. We have to reboot the router ever now and then, and for some reason after the reboot the performance get better.
Leo Laohoo
What is the speed of the WAN link?
See below:
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Description: Internet ADSL Connection
  Internet address is 84.252.240.78/32
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 1/255, rxload 255/255
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi3
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 5d17h
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
     46586777 packets input, 3920196096 bytes
     42175464 packets output, 3980009007 bytes
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
An aDSL with only 56 Kbps?  Is that correct?
Is this link use for Internet?  Do you have a default route?  If so, is next hop for the default an IP or is it the interface?
ATM0/0/0 is up, line protocol is up
  Hardware is MPC ATMSAR, address is 7cad.74e1.7583 (bia 7cad.74e1.7583)
  MTU 1600 bytes, sub MTU 1600, BW 1023 Kbit/sec, DLY 360 usec,
     reliability 255/255, txload 9/255, rxload 255/255
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  4 maximum active VCs, 1024 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 171693
  Queueing strategy: Per VC Queueing
  30 second input rate 1040000 bits/sec, 92 packets/sec
  30 second output rate 38000 bits/sec, 66 packets/sec
     47058637 packets input, 282454214 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     42338613 packets output, 3927546206 bytes, 0 underruns
     0 unknown protocol drops
