Smart license registration lost
Petr Nyvlt
I have issue with Cat9k smart license.
The switches was successfully registered  to CSSM.
After reload the license information dissapeared and the switches run again in evaluation mode.
Smart Licensing Status
Smart Licensing is ENABLED
Registration:
  Status: UNREGISTERED
  Export-Controlled Functionality: Not Allowed
License Authorization:
  Status: EVAL MODE
Renewing the license with old token is not possible. The token is already expired.
 %SMART_LIC-3-AGENT_REG_FAILED: Smart Agent for Licensing Registration with the Cisco Smart Software Manager or satellite failed: Error received from Smart Software Manager: {"token":["The token 'x...%0A' is not valid."]}
I asked customer to generate new token, but the registration fails with this error :
 %SMART_LIC-3-AGENT_REG_FAILED: Smart Agent for Licensing Registration with the Cisco Smart Software Manager or satellite failed: Error received from Smart Software Manager: The product regid.2017-05.com.cisc......a and sudi containing udiSerialNumber:FCW....,udiPid:C9500-16X has already been registered.
How to proceed with that?
Is there some command to renew the licence registration for already registered switch?
Or do I have to ask customer to  deregister the switch from CSSM portal?
I am forced to use smart license because of 16.9.x IOSXE
I am only interested in Network Advantage licenses. What happens when evaluation licenses expire? Do the switches downgrade to Network Essentials license or stay with Advantage?
allureddy
I have this problem too. I have new switches with 16.9.2 with Eval license mode. How to make them registered?
I solved that with new registration token and parameter "force" in the end of the line
license smart register idtoken <idtoken> force
thank you Petr, that fix the problem
