smtp data
networkforumman
Given two sites linked with two WAN connections, can smtp traffic be routed accross one of the links and the other link be used for all other data?
Thanks.
dmbutko
Yes of course.
Try using policy routing (route map) to matching smtp traffic and transmitting it to specific interface.
Use this link: http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75d2.html
Match traffic by access-list, then set interface in route-map, and apply the route-map in LAN interfaces of both routers.
Thanks for your help.
