SNMP Filtering out Link-3-UPDOWN
TOM FRANCHINA
I would like to send out only meaningful log information to the syslog.  I would like to filter out %LINK-3-UPDOWN: and  %LINEPROTO-5-UPDOWN: going to the syslog but I would like them to be visable in the show logging as it is useful for trouble shooting.
I don't want to just send level 2 and below because there are problem at level 4 and 5 that are important to know.
Switch Ports Model              SW Version            SW Image
     1 52    WS-C3750-48TS      12.2(53)SE            C3750-IPBASEK9-M
Tom
Rolf Fischer
Level 9
Level 9
Tom,
I assume you're asking for syslog, not SNMP?
A logging discriminator for host logging could be what you're looking for:
http://www.cisco.com/en/US/docs/ios-xml/ios/esm/command/esm-cr-a1.html#GUID-B7887982-361D-4C8E-BAAF-977AEC1C78EA
As you surely know, the syslog format starts like this:
%FACILITY-[SUBFACILITY-]SEVERITY-MNEMONIC
The messages, you don't want to be send to your syslog server both have "UPDOWN" as MNEMONIC.
So you could simply configure ("LINKCHANGE" ist just a name, change it if you like to):
logging discriminator LINKCHANGE mnemonics drops UPDOWN
logging host discriminator LINKCHANGE
Note: This discriminates all syslog messages with "UPDOWN" as mnemonic from sending to the syslog server. There might be other messages that match this pattern, although I don't know any.
Rolf
Thanks very much... this does what I was looking for.
Rolf,
Can I have multiple disciminators applied to one Server. I could not find a way to do that. For example UPDOWN and POWER_DETECTED
Thanks again
