SNMP trap (Bad link detected)
Aknab Aknab
I enable cisco switch 3560x all traps (snmp-server enable traps).
Monitoring server always sending BAD link detected when the interface go up and down.
Should i use snmp trap link-status on each switch interface to disable it?
Is there a global command to disable interface link up/down status. Thanks
kirannetworxx
try "no logging console" to disable
