which memory used to store ip routing table ?
mohammed hashim
hi all
which memory in cisco routers is used to store ip routing table ?
thanks
Reza Sharifi
Hi.
DRAM.  If you need to contain the entire Internet routing table, you need at least 512Mb of DRAM.
daniel.dib
Level 7
Level 7
It depends on the plaform. There is a good Cisco Live presentation by Pete Lumbis:
IOS Routing Internals
BRKARC-2350
On CPU based platforms it would be stored in RAM. So with more RAM it's easy to fit more routes. On hardware based platforms (ASIC) it would be stored in TCAM. TCAM is faster but also expensive and not as easy to upgrade.
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
