02-04-2009 11:36 AM - edited 03-04-2019 01:06 AM
Does anyone know if there is functionality to set up SNMP traps for packet loss on a priority queue in a LLQ QoS policy? In a scenario where you have many connecting routers, it would be nice to have alerts configured for a situation where not enough bandwidth is set up for the voice priority queue on the WAN service policy.
Any clues would be greatly appreciated!
Solved! Go to Solution.
02-04-2009 11:52 AM
I didn't know if there was a command I can run on the routers themselves to make sure they are sending the traps when the priority queue sees a drop
Sorry, there isn't. You need a NMS Tool to do that for you. Sending traps while packets are dropping will place an extra burden into the router's CPU.
If you are using Modular QoS CLI (MQC), you can view the drops in the priority queue with the show policy-map interface command. While this is a manual process, it provides some level of monitoring for those w/o a NMS tool such as QPM.
__
Edison.
02-04-2009 11:45 AM
CiscoWorks QPM 4.0 will do the job:
HTH,
__
Edison.
02-04-2009 11:47 AM
We are using a 3rd party SNMP utility, so I didn't know if there was a command I can run on the routers themselves to make sure they are sending the traps when the priority queue sees a drop.
02-04-2009 11:52 AM
__
Edison.
02-04-2009 11:56 AM
OK thanks!
02-04-2009 12:39 PM
It might be possible to accomplish that using Embedded Event Manager (EEM) found in the later IOSs.
