So many arps from ISP on Internet CCT
Nirbhai Gill
I forgot the command i used to have on my cisco which would block the internet arps coming into my router and instead i would get only one arp from ISP and then I tried setting up Configuration professional and selected primary WAN interface which wiped out my WAN interface config and now I am recieving whole lots of Internet Arps on WAN. Can someone please help me disable this.?
Example
Internet  192.168.20.6           10   00d9.xxxx.xxxx  ARPA   Vlan20
Internet  192.168.30.1            -   2c54.xxxx.xxxx  ARPA   Vlan30
Internet  198.41.214.67          21   0023.xxxx.xxxx  ARPA   GigabitEthernet1  <<<<INTERNET WAN Interface
Internet  198.41.214.68          15   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  198.252.206.25         15   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  199.19.167.36          15   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  199.182.221.110        25   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  205.185.208.127        19   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  205.234.175.175        15   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  206.108.0.131          14   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  206.186.121.125        29   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  207.46.7.252           23   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  207.102.177.22         28   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  207.102.177.120        29   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  207.102.185.216        29   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  207.210.46.249         24   0023.xxxx.xxxx  ARPA   GigabitEthernet1
Internet  207.228.125.115        15   0023.xxxx.xxxx  ARPA   GigabitEthernet1
before this there was only one arp from Gi1.
WAN Interface Config
interface GigabitEthernet1
 description PrimaryWAN
 ip address dhcp
 ip access-group UnwantedStuff in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip pim sparse-dense-mode
 ip nat outside
 ip virtual-reassembly in max-reassemblies 1024
 ip igmp version 3
 load-interval 30
 duplex auto
 speed auto
end
Thanks and regards!
Philip D'Ath
Most likely, you have your default route wrong.  Mostly like, you are routing it via an interface rather than a specific IP address.
The only default route you should have configured is:
ip route 0.0.0.0 0.0.0.0 DHCP
Philip D'Ath
Thanks for the reply..Yeah fixed it earlier in the evening..it seems like CCP changed the route too point to interface rather than ip when I selected the WAN through CCP..I never anticipated it would do that though as I thought it would have only wiped WAN config  but it added few other commands too..
