So when we are trying to assign same vrf to two router ospf its giving
pthakkar
So when we are trying to assign same vrf to two router ospf its giving error
This is in Cisco 9500 Switch %VRF specified does not match existing router
Mark Elsen
  - FYI : https://community.cisco.com/t5/other-network-architecture-subjects/loading-ospf-configuration-after-reboot/m-p/385450/highlight/true#M135384
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Harold Ritter
Hi @pthakkar ,
The issue is that you are trying to configure ospf for the VRF (router ospf 1995 vrf pwmgmt)  with the same process-id that is already being used by the ospf process used for the global routing table (router ospf 1995). Please use a different process-id for the VRF and it should fix the issue.
Joseph W. Doherty
router ospf x vrf pw1
router ospf 3500 vrf mgmt2
router ospf 3600 vrf mgmt
router ospf 1995
CLT-FW-DIST-Stack#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CLT-FW-DIST-Stack(config)#router ospf 3600 vr
CLT-FW-DIST-Stack(config)#router ospf 1995 vrf pwmgmt
Ah, I don't see router ospf 1995 assigned to vrf pwmgmt.
Hi friend
Can you more elaborate.
Also are you sure you add vrf (it RD) beofre use it with ospf
MHM
