How to configure Carrier Aggregation WWAN (LTE Adv 3.0 Cat6) on a 1100 series ISR
AlexW22
Hi all,
I was looking through my 1100 Series ISR data sheet and Software Configuration Guide to find the commands / config examples for carrier aggregation that should be supported by this hardware. Unfortunately, I was unable to find info on how to configure this. I would like to configure aggregation between band 3+(7,20) stated as supported in the datasheet. My understanding is that this is an aggregation between band 3 (1800MHz) + band 7 (2600MHz) or band 20 (800MHz)
[EDIT] Found this Network Interface Module Configuration guide for the ISR 4000 series. It mentions band aggregation as well but again no configuration examples or  CLI commands that give any info on where to start.
Would highly appreciate any information on this.
OmkarBhalekar
Hi Alex,
Any luck finding the config guide for Carrier Aggregation for ISR? . In my case  I am trying to use a IR1101-K9 with P-LTEAP18-GL.
