09-26-2011 07:37 AM - edited 03-04-2019 01:44 PM
HI all,
7200 VXR router got rebooted after due software crash dump.I have replaced NPE-G1 but still router is rebooting. Currently I am running with 12.4 (15)T 13 IOS.Crash Dump file is attached.
Thanks a lot in advance
Ajith.
09-26-2011 07:57 AM
it smells buggy:
sep 26 07:45:54: %SYS-2-GETBUF: Bad getbuffer, bytes= 37956 -Process= "IP Input", ipl= 0, pid= 78, -Traceback= 0x614CCC54 0x602F6270 0x61B37188 0x61B3808C 0x61B23DA8 0x61B253AC 0x61B257C4 0x61B25844 0x61B25A48 0x62B32184 0x62B32168
CSCte78768 - Logging error message Bad getbuffer in process "IP Input"
though it should not lead to a reboot.
And one of the latest functions in the traceback is related to SNMP, also we have this in the log:
sep 26 07:52:52: %SYS-3-CPUHOG: Task is running for (2004)msecs, more than (2000)msecs (88/44),process = SNMP ENGINE.
do you poll this device currently?
also, how does the complete log look like, if you are saying the box is currently keep reloading, I'd expect to see something starting from ROM and end up with a reload. You could attach it to the thread.
HTH,
Ivan.
P.S. forgot to mention, there are a few malloc's:
001559: sep 26 07:52:54: %SYS-6-MTRACE: mallocfree: addr, pc
6804C4F8,6001D480 6804C4F8,6289B820 6804C4F8,3000052E 6804C4F8,6001D480
6804C4F8,6289B820 6804C4F8,3000052E 6804D404,6287C970 6804D404,4000017C
001560: sep 26 07:52:54: %SYS-6-MTRACE: mallocfree: addr, pc
674E3500,6287C970 674E3500,4000017C 683023D8,6289B820 683023D8,300000AE
682A5F20,6287C970 682A5F20,4000017C 682ADFD4,6289B820 682ADFD4,300000B4 001559:
Message was edited by: Ivan Krimmel
09-26-2011 08:11 AM
generic questions:
1. How long have you been running this version of IOS ?
2. When was the last configuration change on this device ?
09-26-2011 07:03 PM
This IOS is running for more than 6 months and last config change was happened during the NPE-G1 replacement.
09-27-2011 12:45 AM
I guess you missed out my inquiry:
do you poll this device currently? if yes, what and how often/intensive?
also, how does the complete log look like, if you are saying that the box is currently keep reloading, I'd expect to see a log with something starting from ROM and end up with a reload. You could attach it to the thread.
it'd be helpful to learn the answers to these questions.
Ivan.
