Unequal cost Paths Load Balancing with Eigrp
leonardo-f
Hello Guys!
I have a Branch office router (R1) with  two  wan links to my server farm, the first is a Frame Relay link with a CIR of 128k, the second is a satellite link with a CIR of 256k configured through a tunnel, each with a different service provider and different end routers (R2 and R3), I would like to share the load equitably between the two links.  (Attachment: Netwok Diagram)
I used the Variance 2 command on R1 but the load sharing proportion of outgoing traffic  between the two links is about 90/10 (90% over the FR Link 10% over the sat link) and all the incoming traffic only uses the FR link.
The sat link has a  greater delay than the FR  so i adjust the delay values at the interface of the sat link and the proportion was better (about 70% - 30% )
I would like to know the best way to implement load balancing according to my situation in the most equitable way to both outgoing and incoming traffic.
SH IP EIGRP TOPOLOGY
IP-EIGRP Topology Table for AS(100)/ID(10.255.54.18)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 0.0.0.0/0, 1 successors, FD is 10642432
        via 10.255.54.17 (10642432/28160), Tunnel454
        via 10.1.54.17 (20512256/768), Serial0/1/0.454
P 10.1.54.16/30, 1 successors, FD is 20512000
        via Connected, Serial0/1/0.454
P 10.255.54.16/30, 1 successors, FD is 10639872
        via Connected, Tunnel454
P 10.204.54.0/24, 1 successors, FD is 28160
        via Connected, FastEthernet0/0
* SH IP EIGRP NEIGHBORS
sh ip eigrp neighbors
IP-EIGRP neighbors for process 100
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   10.255.54.17            Tu454             14 06:02:51  690  4140  0  6949981
1   10.1.54.17              Se0/1/0.454       14 06:09:17   37  1140  0  302302126
2 Accepted Solutions
Mohamed Sobair
Level 7
Level 7
I couldnt view the attached file, however , as a fundamental statement, is that Loadbalancing is performed outbound direction on the router, you cant influence inbound loadbalancing on the local router, but you can have some sort of loadsharing.
You can spilit your subnet at the DR main Site of the Servers, and lets R2 and R3 sends different subnets to R1 along with the main subnet. This way , you can have loadsharing inbound.
Mohamed
Marwan ALshawi
well this design might lead to out of sequence TCP or asymmetrical routing why you don't use load sharing using PBR with IP sla to make it reliable to load share the source destination traffic selectively
or just use it in active standby
or the other option which is a bit more complicated if you never done it using Performance Routing PfR where you can loadbalance 50/50 or 70/30 based on link utilization for example
http://docwiki.cisco.com/wiki/PfR:Solutions:EnterpriseData
https://supportforums.cisco.com/docs/DOC-8353
Hope this help
6 Replies 6
Kelvin Willacey
Level 4
Level 4
Are you saying that one end has one router with both links and the other end has a router for each link? If that's the case only one direction can load balance traffic, unless there is another routing device behind the two routers.
Thats correct one end have 1 router with two links and the other end have 1 router for each link
Mohamed Sobair
Level 7
Level 7
Mohamed
dslice
In case you didn't know it, EIGRP is responsible for installing the routes in the rib, but doesn't directly affect the actual percentage of traffic forwarded through each path. That's done by the forwarding code (normally CEF) and can be influenced by the metrics and thus the load share value set for each path, but it's hardly exact. Since CEF can use different criteria for building CEF entries (I think default for most trains is source/dest) which means the characteristics of the actual traffic can change the proportions.
You can and should set the metrics to make the ratio for the load share values match what you want but don't be surprised if the results aren't exactly what you want. Also recognize that it's possible you'll end up with out of order packets for your traffic (depending on your CEF load balancing behavior) which could possibly impact your flow performance depending on how tolerant your applications are to this.
Marwan ALshawi
Hope this help
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
EIGRP unequal load balancing easily configured R1.  To do similar on R2 or R3, believe you need to make one of the two routers gateway for all outbound traffic and then account for the LAN hop between them also insuring redirect are not provided to the hosts.  (You might also use GLBP on R2 and R3 which can also be configured for unequal/proportional usage.)
EIGRP will proportionally route individual flows (unless you enable per packet load balancing - not recommended).  As such, at any one time actual link load usage is likely not to match expected load balancing although long term average usually does.  (Similar issue with GLBP although is proportions by host MAC and as such is more likely not to meet short term or long term proportions unless all the sending hosts transmit about the same amount of traffic.)
OER/PfR that supports PIRO could be implements on one or both sides.  It, unlike routing or gateway load balancing, dynamically load balances.  If used, you shouldn't need to use routing or gateway load balancing, although since OER/PfR takes some time to make adjustments, I've found routing and gateway load balancing provides a course load balancing which OER/PfR "tunes".  Even it, again without packet-by-packet, will not balance a single flow.  (NB: there's much more to OER/PfR's balancing capabilities.)
