Software Defined Access
In a few words What is SDA? What are the benefits?
Leo Laohoo
Go HERE.
inderdeeps
Level 4
Level 4
Well, SDA is so called Software defined Access where Cisco is creating the Fabric and using VXLAN and LISP protocols as a Data plane and Control Plane. No longer you are creating VLANs now there is a concept of SGT. If you want to understand the basics of the SD-Access, Please go through the below mentioned link for your reference
http://www.routexp.com/2017/07/sd-access-fabric-network-automation-and.html
ChuckMcF
IMHO,
Security - ISE integration, SGTs, CTS, Guest portal, VRF segregation are just a few examples.
Ease of deployment - You can configure a new device on your network in under an hour. You can add new networks (SGTs/IP Pools) and deploy across the network in minutes.
Uniform Device Configuration - If your network is required to comply with STIGs then you'l really appreciate this benefit.
For more info visit: https://www.cisco.com/c/en/us/solutions/enterprise-networks/software-defined-access/index.html#~stickynav=2
