Software Feature Pack
godlam
Do they know what is the different between the feature pack in IOS software? Such as Advanced IP Service and IP/ADSL/FW/IDS PLUS IPSEC 3DES . Thanks.
Godwin
What is the meaning of article? You mean the Advanced Service having glbp or there is a different between them. Thanks.
Godwin
Godwin, IP/FW/IDS/ADSL IPSEC/3DEs is a feature set strictly used for 1700s. This naming convention of feature sets have changed starting with newer routers (1800/2800/3800) etc.
IP base feature sets gives you basic IP features.
IP Voice feature set gives you voice features
Advanced security feature set gives you security features (FW + IPSEC/3DES)
ADvanced IP Services combines IP Voice and Security features. (SP Services is a subset)
This link should illustrate.
http://www.cisco.com/en/US/products/ps5855/prod_bulletin0900aecd802a94d4.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
