CGMP used by Cisco LAN switches
zillah2004
While I was searching I found this on net: it was answer to one of the CCIE question:
CGMP is the Cisco Group Management Protocol (CGMP) which is multicast protocol used by Cisco LAN switched , and nor routers.
Is this right ?
5 Replies 5
Not applicable
aravindhs
cgmp is an alternative to igmp-snooping.
The essence of this by a switch is to bind the interested propriate multicast group to the appropriate switchport.
cgmp needs assistance by the router and hence it runs both on the switch and the router.
for eg. when a host sends an igmp report to the router requesting it to be added to the multicast group as a client, the cgmp enabled router sends a cgmp join message to the switch with the mac-address of the igmp report sender and the multicast group that was requested for in the igmp report msg.
Hence CGMP is required for multicast at layer2 and assisted by the router.
At the router, cgmp needs to be enabled at the interface level.
And, cgmp and igmp-snooping are mutually exclusive.
hope this helps
cheers
Arav
zillah2004
Thanks Arav for this explaination.
What about the question? can we consider it right ?
As you know if have to enable CGMP om switch and router, that means (for my understanding) we have used it on both devices, not only one,,,Am I right ?
Yes, the answer can be considered right.
Cheers
