Software upgrade with no ethernet
yavuz.ozdemir
I have a 3640 router with a 2FE2W-V2 but this module is not recognize by the router, due to it I want to make a upgrade software but
my procedure is I connect a cross-cable from the fast ethernet to my pc, so have you an idea how I can make the upgrade without ethernet connection?
Thanks in advance.
5 Replies 5
mahmoodmkl
Level 7
Level 7
Well i think u can xmodem procedure for this.
Mahmood
Thanks Mahmood. Have you an idea where I can to find the procedure?
If you have physical access to the router, change the speed of the console port to as fast as you can get (I've only been able to get up to about 115000), then once you've got that working, just issue a copy xmodem flash. I'd recommend hyperterminal for this as it has a good send feature.
HTH,
Shane
It's right, thanks to all for your helps.
