Software
scollins
If I need VPN and Firewall in addition to basic functions on a 2821 router will IP Base be adequate or do I need an enahnced software bundle?
Richard Burts
Stuart
IP Base will not be adequate for either VPN or for firewall. For these functions you would need at least Advanced Security or perhaps Advanced IP Services.
Rick
Rick
Is there a document that details the various feature sets associated with each software bundle?
Stuart
I hope that this link will be helpful:
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_bulletin0900aecd802a9493.html
It deals with the feature set packaging on the 2800 series routers.
Rick
Rick
