solution to divide IP ranges/VLANs without changing servers IP
webstd.design
Hello. Is there any solution to divide IP ranges/VLANs without changing servers IP?\
Many thanks
5 Replies 5
IP Subnetting is generally used for dividing IP ranges...
Not sure what exactly you need is.
Smitesh
Tagir Temirgaliyev
HI
if for example server A has addres 192.168.1.1/24 and server B has addres 192.168.1.5/24 so you can isolate this 2 servers from each other making 2 subnets  192.168.1.0/30 and 192.168.1.4/30
explain what are your needs and what kind of network peripherals you r using.I mean if you have cisco or other vandor manage switch then it will very easy for you by subnetting concept .
send us full imformation about you network diagram or etc.
Based on your example of IPs and subnets used; there is no way unless you do IP restructuring....
Smitesh
There are servers and PCs in one subnet. We must devide this by two separate VLANs. The question what is the best solution as servers are used by many PCs, other servers outside the LAN. Also actual subnet is involved in FW rules for PCs to access outside. There are two evils but we should consider what is better - move PCs from actual to separate VLAN or move servers from actual to separate new VLAN
