Solve Netbios issue with helper-address ?
netadmincsm
Hi All
I need to move around 4 PC from a flat network to a particular subnet (VLAN) into our router.
When  all the PC was into the flat network everything was fine regarding  Netbios broadcast (ex.: when PC1 wanted to talk with PC3 with the PC's  name, PC1 did a netbios broadcast asking for the ip address of PC3)
NOTE : There's no domain server into that network.
But now, with a couple a PCs into a new VLAN, the broadcast wont work anymore.
VLAN10
PC1, PC2,
VLAN20
PC3, PC4, PC5, PC6
I  put an "ip helper-address" for PC3-6 into the vlan10 and I put an "ip  helper-address" for PC1, 2 into VLAN20.  Everything is nor working fine  but...
Does it a good solution to add ip helper-address to solve this problem ?
Thank you very much.
   If we can do internal dns, we should. In your case,you can do something like this.
Let's say we only need to forward udp/137 and udp/138 from VLAN10 to VLAN20. Lets say VLAN 20 is 192.168.20.0/24.
Switch(conf)#no ip forward protocol udp 37
Switch(conf)#no ip forward protocol udp 49
Switch(conf)#no ip forward protocol udp 53
Switch(conf)#no ip forward protocol udp 67
Switch(conf)#no ip forward protocol udp 68
Switch(conf)#no ip forward protocol udp 69
Switch(conf)#interface vlan 10
Switch(conf-if)#ip helper-address 192.168.20.255
Switch(conf-if)interface vlan 20
Switch(conf-if)#ip directed-broadcast
    If you don't want to add each host,you can do this. And let us know how things work out.
HTH,
Toshi
10 Replies 10
vmiller
Level 7
Level 7
Asked and answered. you fixed it, by definition thats good.
As long as you understand what the helper is doing. I trust you are doing the helper for port 137 ?
There are some broadcasts that do need to be forwarded, This is one of them.
Yes it's for 137 or 138 maybe
Is it normal that I have to use a helper-address line for each PC on each vlan ?
Thanks for the answer
HTH,
Toshi
Hi Toshi,
ip directed broadcast is not for all 255s, ain't it? so it will not solve the problem as Netbios is broadcasting to all 255s.
Can you confirm/infirm my thought.
Regards.
Alain.
Hi Alain,
      In this case,"ip directed-broadcast" is actually used to convert 192.168.20.255 to FF-FF-FF-FF-FF-FF to allow all nodes in VLAN20 to receive udp/137 and udp/138.  Its disabled by default. You can check it by using "show ip interface "
HTH,
Toshi
Hi Toshi,
ok I agree with what you said but the netbios layer 3 broadcast is 255.255.255.255 so when it comes into router it will be blocked and the only way to solve this issue is using ip helper-adress or a WINS server
I think the ip directed broadcast which by the way is disabled by default for security measures is another feature.
Again correct me if I'm wrong.
Regards.
Alain.
Hi Alian,
      Well, I already posted this requirement.
Let's see what is going on.
1. Hosts on VLAN-10 uses NetBios to solve the names of PCs on VLAN-20.
2. Switch takes care of Dst Addr:255.255.255.255 and Dst port:UDP/137 and then convert it to 192.168.20.255 because of "ip helper-address 192.168.20.255" configured on VLAN-10 inteface.
3. Switch converts 192.168.20.255 to FF-FF-FF-FF-FF-FF and send it to VLAN-20 segmant because of "ip directed-broadcast" configured on VLAN-20 interface.
    If you want to see the detailed packets,you can lab it up and use "debug ip packet detail".  It should work like a charm. Why do I do this? Because you don't need to use multiple statements of "ip helper-address" commands to define hosts. As you know, ip helper-address forwards many udp ports by default. you can select or define new udp ports you want.
HTH,
Toshi
Hi Toshi,
192.168.20.255
because of "
ok I had overlooked this helper-address  towards a directed broadcast I hadn't used this feature as of yet.
But wouldn't it be more secure to configure a wins server rather than this trick which is great but reenables ip directed-broadcast on the interface.
This way he would also get rid of those horrendous netbios broadcasts name resolutions.
Regards.
Alain.
Hi Alian
You are right. Its a security concern. Thats why I told him that if we can do internal dns,we should.
Thank you veru much for all your questions and answers.  It really helps me too figure out what I will doing.
Your help was very appreciated.
