SOLVED: 1841 unit not routing from lab to home network
DeltaWasp
I have setup a very simple home lab that consists of two networks: 172.16.0.0/16 (inner lan) and a 10.0.0.0/8 (outer lan), my home network is 192.168.1.0/24 which has egress to the Internet via a fibre router at 192.168.1.1 (also provides dns forwarding etc).
Nothing inside my lab network can communicate with anything on the home network, except router1 which can ping anything on the home net but doesn't seem to want to route traffic from the lab nets to the home net.
Everything in the lab nets can ping everything else inside the lab nets.
I can connect from my PC on the home net to anything inside the lab with no issues.
I have erased both routers and setup from scratch.
Any help would be very appreciated.
 Router configs are below:
router1:
router1#sh run
Building configuration...
Current configuration : 1007 bytes
! Last configuration change at 14:45:52 UTC Mon Jan 2 2006
! NVRAM config last updated at 14:45:58 UTC Mon Jan 2 2006
version 15.1
hostname router1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
license udi pid CISCO1841 sn FCZ1236906K
interface FastEthernet0/0
 ip address 192.168.1.254 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 10.0.0.1 255.0.0.0
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
 no fair-queue
 clock rate 2000000
router rip
 network 10.0.0.0
 network 172.16.0.0
 network 192.168.1.0
ip forward-protocol nd
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
 router2:
router2#sh run
Current configuration : 871 bytes
! Last configuration change at 14:56:39 UTC Sun Nov 5 2023
version 15.1
hostname router2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
license udi pid CISCO1841 sn FCZ1410C0QG
 ip address 10.0.0.254 255.0.0.0
 duplex auto
 speed auto
 ip address 172.16.0.1 255.255.0.0
 duplex auto
 speed auto
 no ip address
 shutdown
 clock rate 2000000
router rip
 network 10.0.0.0
 network 172.16.0.0
 network 192.168.1.0
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input all
end
DeltaWasp
A combination of dynamic routing and NAT helped me solve this with inspiration from this video: https://www.youtube.com/watch?v=mBKpwmHk-fk
DeltaWasp
