Some way to create Vlan Routing? without Routing on Stick, my devices no support it.
Zagam
Hi there!
Somebody have one though about how can do Vlan Routing? I have two Routers (887,899) not support router on stick and subinterfaces, so, any idea?
Regards!!
Seb Rupik
Hi there,
Both of those models support SVIs. The config would look like:
int vlan 10
  ip address 192.168.10.254 255.255.255.0
...as opposed to a routed interface.
Can you share your desired topology and running configs and we'll be able to advise on the correct config.
cheers,
Seb.
Seb Rupik
Hi there,
int vlan 10
cheers,
Seb.
Thanks a lot!
I created SVI and this was the solution.
Regards!
Hello
If they don't support sub interfaces do they support trunks or does this router have any switch module installed so to use Switch Virtual Interlaces (SVI) instead.?
Can you post the the output of the following;
Show version
Kind Regards
Paul
Jaderson Pessoa
@Zagam hello,
1. 887 supports 8 VLAN's meaning you can configure 8 logical "interface vlan[number] that are associated with the Layer2 VLAN. These logical interfaces can be configured with IP addresses to be the default gateways.
Reference:
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/vlanconf.html
2. 877 should be backward compatible with ADSL ITU G992.1. You can verify this through Table 7 - hardware specifications
See reference:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976.html
more information: https://community.cisco.com/t5/switching/cisco-887-svi-vlan-question/td-p/1629314
Jaderson Pessoa
*** Rate All Helpful Responses ***
