Span monitor session for VLAN 1
SlipperyPete
We'd like to create a monitor session that covers all the traffic on a Catalyst 6513 switch. The only VLAN currently configured on the switch is the native VLAN 1, so I figured I could span the entire VLAN thus capture all traffic that traverses the switch. However, while the IOS allows me to create the session and enter VLAN 1 as the source VLAN, when I check the session it shows as having no source VLAN configured. Am I not allowed to span the switches native VLAN?
Giuseppe Larosa
Hello Patrick,
just a warning even a powerful C6513 can be impaired if the traffic volume is much greater then the destination port speed: we have seen cpu to go as high as 100% on C6509 for a span session trying to push 3Gbps of traffic out a single GE port where the IDS is connected.
the following chapter from ios 12.2SXF can help
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/span.html#wp1102614
and the command reference for monitor session command
http://www.cisco.com/en/US/docs/ios/lanswitch/command/reference/lsw_m1.html#wp1015931
it is clearly stated that valid vlan-id is 1-4094 on C6500/7600.
Hope to help
Giuseppe
