SPAN Port Destination
mthomas777
I am new to creating a SPAN. When creating a span port destination on a Catalyst switch such as a 6509, does the destination port need to be setup as routed port (no switchport) or a switch port (eg: switchport, switchport access vlan x). The source port will be setup to capture VLAN and physical Interface traffic.
thanks.
6 Replies 6
The destination port (if you are going to connect a server or PC) should not have any configuration, it should be configured by default.
monitor session 1 source interface g1/x both
monitor session 1 destination interface g1/Y
or
monitor session 1 source vlan X both
interface g1/Y
description SNIFFER
no shutdown
 * both is receiver/transmitter by default. Port and VLAN as source on the same session is not recommended. You will need 2 sessions.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swspan.html
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/10570-41.html
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you so much Julio. This was really helpful.
Im glad to hear that, it was a pleasure,
Have a great day
Just a recommendation, try to don't mix VLAN and physical ports on the same session.
The best option is create 2 sessions.
monitor session 2 source interface VLAN X both
monitor session 2 destination interface g1/Y
Or if you are going to monitor the VLAN X from a physical port like a trunk, you can make a filter.
Hi Julio,
I wont. thanks for the suggestions.
You are welcome
