Special mac address after show mac address
wfqk
Level 5
Level 5
Hi I got the following mac address after enter command in switch 2960. Anyone can explain it? thank you
SW# sh mac address-table
Mac Address Table
Vlan Mac Address Type Ports
All 0100.0ccc.cccc STATIC CPU
luis_cordova
Richard Burts
Here is a link to a discussion in the Cisco Learning Network which explains this
https://learningnetwork.cisco.com/thread/27560
I hope you find it helpful.
Rick
Rick
Thanks for your reply. From the post, we can see that is special mac address. the question is show mac address is one command that we often use. why we do not often see these mac address or its similar one when using the command? In another word, we do not see the mac address in most situation, and we rarely can see these mac address when using the show mac address.
