Split DNS for use by router itself
bbosch4210
I have a requirement for the router itself to use multiple DNS servers for name resolution. I've configured view-groups and they work when the router (ISR4431) is configured as a DNS server. But when I try and ping the hosts from the router itself, only the default view is used, not the others with lower evaluation orders.
ip dns view specific
 domain name-server 1.1.1.1
ip dns view default
 domain name-server 2.2.2.2
ip dns view-list split-dns-test
 view specific 10
  restrict name-group 1
 view default 100
ip dns name-list 1 permit TEST
ip dns server view-group split-dns-test
ip dns server
end
debug ip domain
Shows 2.2.2.2 used.
When I try the same from another host (With this router as DNS server), then 1.1.1.1 is used. So I know that the name-list is correct.
Anyone able to explain this?
how do you test the host ping, do you specify a source interface ? Post the full config of your router...
