split tunnel and local access to printers
mistryj
I have split tunneling enabled on Cisco Router and using Cisco VPN client to connect PC to office as well as browse local Internet.
However when I want to print to a local printer I cannot. I keep having to add static routes on the PC to allow this. Then having to remove routes when the VPN session is terminated.
It's a workaround but not trulely workable.
Is there a way to configure routes on Router ?
Peter Paluch
This problem would suggest that either the split tunnel is not configured properly on the router, or the PC is for some reason not accepting the routes that should be made available through the tunnel.
Can you post the relevant sections of your configuration on the router that relate to the VPN and the split tunneling? Also, what IP address does the printer have? Can you also post the output of the route print after you just log into the VPN - without the manually added routes?
Thanks!
Best regards,
Peter
mistryj
Problem resolved with static routes on PC.
