SR520
gmatthews
I have an SR520 that is failing,  what would you suggest to replace this type of unit, (includes firewall)
cchamorr
Level 5
Level 5
According to the EOL notice for this device,
http://www.cisco.com/c/en/us/products/collateral/routers/sr-500-series-secure-routers/end_of_life_notice_c51-695719.html
The replacement is the Cisco 800 series router.
Just look at the link above and you will be able to find the exact replacement based on your current model of SR.
I hope this helps
Moin Ilyas
Level 4
Level 4
