SRP541W not routing between networks
congo.congo
hello,
i have a SRP541W which I plug a cable into my Cisco RVS4000 directly.
The net on the SRP541W is 172.1.72.1/24 and the RVS4000 is hosting 10.26.101.1/24 - however, whenever connected to the SRP541W via wifi i cant connect to the internet. When connected to the RVS4000 everything works fine.
I would not only like it to be able to route to internet via the RVS4000 unit, but any unit that might release an IP adress for the SRP541W via cable, if possible.
The SRP541W  is having a cable inserted into WAN1 from a RVS4000 LAN port. When i go the the admin page of SRP541W, i can perfectly ping google for instance. Also it shows that IP is issued normally and connected...
I am not too much of a networking kinda guy - so i sincerely hope someone can help me out :=)
br
congo
miewhite
Hi Thomas,
It sounds like it is an issue with double NATing.  Each of them is taking a public IP address and translating it to a private IP address.  I recommend that you contact the Cisco Support Community to make sure your problem is addressed.
https://supportforums.cisco.com/index.jspa.
