SSH and Ping to WAN IP not working correctly.
Benjamin Crites
Hey all!
I've run into an issue that i cant seem to figure out. For some reason i can't SSH to my router, and i also cant ping the WAN IP addresses, which i need for my monitoring service. This ones got me stuck so any help is very much appreciated. Here is my sanitized config. Thanks!
version 15.1
service password-encryption
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name xxxxxxx
no ipv6 cef
voice-card 0
username admin privilege 0 password 7 xxxxxxxxxxxxxxxxx
redundancy
interface FastEthernet0/0
 ip address xx.xx.xxx.xxx 255.255.255.240
 ip access-group OutsideIn in
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/1.10
 encapsulation dot1Q 10
 ip address 10.10.100.60 255.255.0.0
interface FastEthernet0/1.20
 encapsulation dot1Q 20
 ip address 10.34.1.1 255.255.240.0
 ip helper-address 10.34.1.7
 ip nat inside
interface FastEthernet0/1.30
 encapsulation dot1Q 30
 ip address 10.60.0.1 255.255.252.0
 ip nat inside
interface FastEthernet0/1.31
 encapsulation dot1Q 31
 ip address 10.31.1.2 255.255.0.0
 ip nat inside
interface FastEthernet0/1.32
 encapsulation dot1Q 32
 ip address 10.32.1.2 255.255.0.0
 ip nat inside
interface FastEthernet0/1.33
 encapsulation dot1Q 33
 ip address 10.33.1.1 255.255.0.0
 ip nat inside
interface FastEthernet0/1.50
 encapsulation dot1Q 50
 ip address 10.50.1.2 255.255.0.0
 ip nat inside
interface FastEthernet0/1.51
 encapsulation dot1Q 51
 ip address 10.51.1.1 255.255.0.0
 ip nat inside
interface FastEthernet0/1.52
 encapsulation dot1Q 52
 ip address 10.52.1.1 255.255.0.0
 ip nat inside
interface FastEthernet0/1.53
 encapsulation dot1Q 53
 ip address 10.53.1.1 255.255.0.0
 no ip redirects
 ip nat inside
interface FastEthernet0/1.54
 encapsulation dot1Q 54
 ip address 10.54.1.1 255.255.0.0
 no ip redirects
 ip nat inside
interface FastEthernet0/1.55
 encapsulation dot1Q 55
 ip address 10.55.1.1 255.255.0.0
 ip nat inside
interface FastEthernet0/1.56
 encapsulation dot1Q 56
 ip address 10.56.1.1 255.255.0.0
 no ip redirects
 ip nat inside
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet0/0 overload
ip nat inside source static tcp 10.34.1.155 8020 interface FastEthernet0/0 8020
ip nat inside source static udp 10.34.1.155 8020 interface FastEthernet0/0 8020
ip nat inside source static tcp 10.34.1.155 8025 interface FastEthernet0/0 8025
ip nat inside source static udp 10.34.1.155 8025 interface FastEthernet0/0 8025
ip nat inside source static tcp 10.34.1.165 8030 interface FastEthernet0/0 8030
ip nat inside source static tcp 10.34.1.165 8035 interface FastEthernet0/0 8035
ip nat inside source static udp 10.34.1.165 8035 interface FastEthernet0/0 8035
ip nat inside source static udp 10.34.1.165 8030 interface FastEthernet0/0 8030
ip nat inside source static tcp 10.34.1.156 8010 interface FastEthernet0/0 8010
ip nat inside source static udp 10.34.1.156 8010 interface FastEthernet0/0 8010
ip nat inside source static tcp 10.34.1.156 8015 interface FastEthernet0/0 8015
ip nat inside source static udp 10.34.1.156 8015 interface FastEthernet0/0 8015
ip nat inside source static tcp 10.34.1.3 8061 interface FastEthernet0/0 8061
ip nat inside source static udp 10.34.1.3 8061 interface FastEthernet0/0 8061
ip nat inside source static tcp 10.34.1.3 8062 interface FastEthernet0/0 8062
ip nat inside source static udp 10.34.1.3 8062 interface FastEthernet0/0 8062
ip nat inside source static tcp 10.34.1.3 8063 interface FastEthernet0/0 8063
ip nat inside source static udp 10.34.1.3 8063 interface FastEthernet0/0 8063
ip nat inside source static tcp 10.34.1.3 8064 interface FastEthernet0/0 8064
ip nat inside source static udp 10.34.1.3 8064 interface FastEthernet0/0 8064
ip nat inside source static tcp 10.34.1.3 8065 interface FastEthernet0/0 8065
ip nat inside source static udp 10.34.1.3 8065 interface FastEthernet0/0 8065
ip nat inside source static tcp 10.34.1.3 8066 interface FastEthernet0/0 8066
ip nat inside source static udp 10.34.1.3 8066 interface FastEthernet0/0 8066
ip nat inside source static tcp 10.34.1.7 3389 interface FastEthernet0/0 3389
ip nat inside source static tcp 10.34.2.87 80 interface FastEthernet0/0 80
ip nat inside source static udp 10.34.2.87 80 interface FastEthernet0/0 80
ip nat inside source static tcp 10.34.1.16 80 interface FastEthernet0/0 8045
ip nat inside source static udp 10.34.1.16 80 interface FastEthernet0/0 8045
ip nat inside source static tcp 10.34.1.17 80 interface FastEthernet0/0 8055
ip nat inside source static udp 10.34.1.17 80 interface FastEthernet0/0 8055
ip nat inside source static tcp 10.34.1.18 80 interface FastEthernet0/0 8056
ip nat inside source static udp 10.34.1.18 80 interface FastEthernet0/0 8056
ip route 0.0.0.0 0.0.0.0 (NEXT HOP)
ip access-list extended OutsideIn
 permit ip any host xx.xx.xxx.xxx
 deny   udp any any eq 1723
 deny   tcp any any eq 1723
 deny   udp any any eq isakmp
 deny   tcp any any eq 500
 deny   udp any any eq non500-isakmp
 deny   tcp any any eq 4500
 permit tcp any host (WAN IP) eq www
 permit tcp any host (WAN IP) eq 8010
 permit udp any host (WAN IP) eq 8010
 permit tcp any host (WAN IP) eq 8015
 permit udp any host (WAN IP) eq 8015
 permit tcp any host (WAN IP) eq 8020
 permit udp any host (WAN IP) eq 8020
 permit tcp any host (WAN IP) eq 8025
 permit udp any host (WAN IP) eq 8025
 permit tcp any host (WAN IP) eq 8030
 permit udp any host (WAN IP) eq 8030
 permit tcp any host (WAN IP) eq 8035
 permit udp any host (WAN IP) eq 8035
 permit tcp any host (WAN IP) eq 8045
 permit udp any host (WAN IP) eq 8045
 permit tcp any host (WAN IP) eq 8055
 permit udp any host (WAN IP) eq 8055
 permit tcp any host (WAN IP) eq 8061
 permit udp any host (WAN IP) eq 8061
 permit tcp any host (WAN IP) eq 8062
 permit udp any host (WAN IP) eq 8062
 permit tcp any host (WAN IP) eq 8063
 permit udp any host (WAN IP) eq 8063
 permit tcp any host (WAN IP) eq 8064
 permit udp any host (WAN IP) eq 8064
 permit tcp any host (WAN IP) eq 8065
 permit udp any host (WAN IP) eq 8065
 permit tcp any host (WAN IP) eq 8066
 permit udp any host (WAN IP) eq 8066
 permit ip any any
ip access-list extended nat
 permit ip any any
logging esm config
logging 10.34.1.7
access-list 50 permit (OUR WAN NETWORK) 0.0.2.255
access-list 100 permit ip any any
control-plane
mgcp profile default
line con 0
 logging synchronous
line aux 0
line vty 0 4
 logging synchronous
 login local
 transport input all
line vty 5 988
 logging synchronous
 login local
 transport input all
scheduler allocate 20000 1000
end
5 Replies 5
Tagir Temirgaliyev
may be your processor overloaded ? may be traffic too big ?
sh proc cpu
sh interface FastEthernet0/0
sh interface FastEthernet0/1
what is the router? 881 ? or 2811 ?
It is a 2811, and it does look like the processors pegged 100% a hand full of times over the last couple of hours. Can this really stop SSH and Ping from working?
  Hardware is MV96340 Ethernet, address is 0022.551a.3b80 (bia 0022.551a.3b80)
  Internet address is XX.XX.XXX.XXX/28
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 4/255, rxload 44/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/1670/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 17259000 bits/sec, 1788 packets/sec
  5 minute output rate 1728000 bits/sec, 1350 packets/sec
     87395905 packets input, 766557199 bytes
     Received 1332539 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 96 throttles
     25676 input errors, 0 CRC, 0 frame, 0 overrun, 25676 ignored
     0 watchdog
     126794802 packets output, 2276449807 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0022.551a.3b81 (bia 0022.551a.3b81)
     reliability 255/255, txload 42/255, rxload 4/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Input queue: 0/75/6376/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 1701000 bits/sec, 1317 packets/sec
  5 minute output rate 16522000 bits/sec, 1712 packets/sec
     129134088 packets input, 3150074778 bytes
     Received 1290762 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 383 throttles
     101275 input errors, 0 CRC, 0 frame, 0 overrun, 101275 ignored
     0 watchdog
     87242554 packets output, 1114685246 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     31588 unknown protocol drops
     1 lost carrier, 0 no carrier
Attached is cpu charts
your processor is overloaded
you have big access-list ip access-list extended OutsideIn
and  permit ip any any
in the end so this access-list is useless
you can remove it
conf t
 no ip access-group OutsideIn in
exi
wr
and see again ping and ssh
and dont forget to rate posts
