SSH and Telnet
michael.buskin
Hi All,
I have just upgraded my WS-2960G-48TC Switches, enabled SSH but I can access the Switch using both protocols - how can I disable Telnet and permit SSH
7 Replies 7
Martin Parry
Level 3
Level 3
You will need to configure ssh access into the vty lines as follows:
line vty 0 4
transport input ssh
You will also need to create keys as follows:
crypto key generate rsa usage modulus 1024
Hope this helps
Martin
royalblues
Level 10
Level 10
Under VTY config configure transport input ssh
line vty 0 4
transport input ssh
This will disable telnet on the vty lines
Narayan
The above two messages are correct. However, you will need to type that command on vty 0 15 as well to ensure all vty lines require ssh connections.
Hi Michael Buskin, With the addition of Narayan's post I'd like to suggest you to put " transport input all" under line vty 0 4. Thanks Goutam
Gautam,
Transport input all would enable telnet on the VTY lines which the user wants to disable :-)
Narayan
Hi Narayan, thanks you are right, just ignore the “disable telnet” I was sleepy. :) Thanks Goutam
jitendra9923
yes u can do by no telnet & enable ssh
used ssh ver 2 for login
