SSH Debug outputs are not showing
I can't see debug outputs from SSH, But I can see debug outputs from console. I have already typed
ter mon
command.
Vinit Jain
Could you please set the logging type to debugging. You can configure:
logging buffered debugging
logging buffered 1000000
You can also set logging monitor debugging debugging as well just to enable debugging on the terminal monitor.
Once you have configured this, you should be able to see the debug outputs.
Please let me know if that helps.
Vinit
--Vinit
Vinit Jain
Vinit
--Vinit
Dear Vinit,
Thanks for the reply and sorry for late reply. It worked fine and I have configured below commands.
logging console
logging monitor
Rajitha
