11-09-2015 01:24 PM - edited 03-05-2019 02:42 AM
How to know which VPN is configured in aggressive mode among list of all VPN's in 2800 router and ASA ?
11-10-2015 05:27 AM
Hi,How to know which VPN is configured in aggressive mode among list of all VPN's in 2800 router and ASA ?
Hello Suresh,
You can check by issueing show crypto iskamp sa , Output will indicate either MM (Main Mode) or AM (Agressive Mode)
Check out the below link for router ipsec tunnel stats
http://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/20641-initaggr.html#comm
Hope it Helps..
-GI
Rate if it Helps
11-10-2015 09:26 AM
Thanks! This helps.
11-10-2015 10:29 PM
Thanks! This helps.
Hello Suresh,
Glad the post has helped, Helpful if you can mark this post has answered so that others can be benfitted. If you have further query then you can fire to Netpro world..:)
-GI
