SSH Error - Failed to Encode IOS
ronaldvg
Hi - SSH suddenly stopped working on our ASR 1001-x.
investigating showed the following:
sho ip ssh
SSH Enabled - version 1.99
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc
MAC Algorithms:hmac-sha1,hmac-sha1-96
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 1024 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): VA.CPCH.HQ.ASR.esvc.us
%SSH: Failed to encode IOS ASN.1 to SECSH format
We tried to zero the existing key and regenerate a new key. no change. reboot the ASR, no change. Telnet works so we are not dead in the water, but we really want to restore SSH access for obvious reasons.
Any help appreciated
Thank you
Ronald
15 Replies 15
Julio E. Moisa
Hi Ronald,
Have you tried enabling SSH version 2?
conf t
ip ssh version 2
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes, and ip ssh ver 1, neither makes any difference.
Thank you
Do you see any error like showed on this link?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu89120/?referring_site=bugquickviewredir
Hi Julio
No, there are no errors in the log file.
Perhaps of interest too, is that this issue prevents the SSH Server process to start on the ASR.
We are running Version 03.16.03.S on both our ASR's The 2nd one has been working just fine.
Try to create a key of 1024 or +
crypto key generate rsa 1024 or 2048
alas tried that too. Zeroid the key first, generated a 512bit key didn't work, zeroid generated a 2048bit key didn't work, generated a 1024bit key, still nothing.
again, there are no errors shown when i generate the key. except that the key doesn't appear to get installed which then prevents the SSH server process to start.
I have the same problem as described, but no solution
conf t
ip domain-name mydomain.net
2048
ip ssh version 2
line vty 0 4
transport input ssh
login local
username admin *****
My telnet connection working fine and I tried to activate SSH2 but cannot too
SW236VLAN109#sh ip ssh
SSH Enabled - version 2.0
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-2020043264
when I tried SSH2 with the right password
Using username "admin".
Access denied
Using keyboard-interactive authentication.
Password:
Access denied
Password:
Access denied
Password:
Did anyone find an answer for this???
Hi Ronaldvg,
Just wanted to make sure if you are trying this on virtual platform like GNS3 or EVE
Saurabh Dhakate
No, we did this directly on the ASR
Ronald
Sriki
Does anyone got the solution for this problem ?
I'm also waiting for the update, got the same problem
shottadrae
I just had this same issue after adding ssh to a switch.
In the logs it showed me trying to connect without a user name. I have logging on for ssh.
ip ssh logging
Dec 18 13:35:29.397: %SSH-5-SSH2_USERAUTH: User '' authentication for SSH2 Session from 10.10.10.10 (tty = 1) using crypto cipher 'aes256-ctr', hmac 'hmac-sha1' Failed
Turns out my ssh config was fine it was the my radius configuration i had the wrong key. after changing the key and then connecting to the device that error went away. Hope that leads you in the right direction.
Having the same issue with an ASR 920,  Anybody have a solution to this issue?
