ssh hangs from router to router?
warren.sullivan
Hi Guys,
Im having a weird issue with ssh from a cisco 1941 to a cisco 1941, it used to work fine, but now it hangs...we have two routers at each site, one primary with an EOC connection to the network, and the other a backup 3G wireless connection to the network, both routers are connected to a switch and HSRP is running between them, due to recent ISP changes, the 3G network went down and has now come back up, so i need to reset the modems to force them to authenticate with our network blar blar blar
My issue is that when i issue a "ssh 10.x.x.x" (LAN IP of the 3G router) it just hangs, i can ping the address fine, there is no access-class set on any VTY lines, transport input ssh is set on both routers and no transport in or output set on either.
nbr-rt01#
nbr-rt01#ping 10.0.80.3
Sending 5, 100-byte ICMP Echos to 10.0.80.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
nbr-rt01#
Here's the thing though, if i RDP to the Site DC and SSH from that server to the 3G router it works fine, i can then even initiate a ssh session to the primary router from the 3G router, i can then jump back on the primary router and establish an SSH session to the 3G router!
this is what i get from a debug;
nbr-rt01#debug ip ssh client
SSH Client debugging is on
nbr-rt01#
nbr-rt01#
nbr-rt01#
nbr-rt01#
nbr-rt01#
nbr-rt01#
nbr-rt01#ssh 10.0.80.3
nbr-rt01#
Sep 24 11:54:23.076 AEST: SSH CLIENT: attempt to create connection failed
Sep 24 11:54:23.076 AEST: SSH CLIENT: failed to create connection
nbr-rt01#
nbr-rt01#
See below for the line VTY config and what happens when i ssh out of the primary to the backup 3G router.
Any ideas?
nbr-rt01#sh run | beg line con 0
line con 0
exec-timeout 30 0
privilege level 15
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 30 0
privilege level 15
logging synchronous
transport input ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 10.0.6.12 prefer
ntp server 10.0.6.13
end
nbr-rt01#
nbr-rt01#
nbr-rt01#
nbr-rt01#ssh 10.0.80.3         (hangs here)
nbr-rt01#
Jeff Van Houten
Level 5
Level 5
Are you running cbac? If so, are you allowing ssh from the router?
As you can see from the output...no
thanks
warren
Ok, sorted, i had ip ssh source address set to a loopback, the 3G router never knew how to get back to the source, when the 3G connection was brought up, ssh went all the way back through the core to the primary routers ip ssh source address!
thanks
warren
