SSH on Router stopped working
daniel86
Hey, can omeone please help me just a minute?
By now my router refuses SSH, but I dont remember that I changed anything.
sh run:
line con 0
password 7
logging synchronous
login authentication local_access
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password 7
logging synchronous
transport input telnet ssh
transport output ssh
line vty 5 15
access-class 99 in vrf-also
privilege level 15
logging synchronous
transport input ssh
Is it because of that one?:
access-list 99 deny   any
Thanks for your help
11 Replies 11
Samer R. Saleem
Level 4
Level 4
yes that could be it or access list 23
if you locked yourself out the device and you didn't save the configs (write the configs to memory) try to reload it
daniel86
I dont know what to do now. Can someone tell me how to activate it again?
CCP via HTTP is working
Hi Daniel,
you can simply remove the ACL 99 if you still have access to the device, but if the device is on a remote site and you cant access anymore, this wouldnt effect anything on the user data flow and you can ask someone to power it off and on again so it will remove the unsaved configs....
I already removed the deny entry in access-list 99. I can not restart the device in business time. I can do it later.
yes, no worries, the user will not be affected by this, as long as you already removed the ACL then even no need to reload...
Ok so what will be the next step to reactivate it again?
Hello
Without not knowing what you did in the first place it hard to know what is negating it.
Please post the config of the router
Kind Regards
Paul
agreed, hard to say without more info. One thing that I still run into occasionally is not having in and out keepalives enabled so you run out of vtys because they're all half open. If you have console access you can check that and see.
Building configuration...
Current configuration : 12759 bytes
! Last configuration change at 10:11:32 UTC Fri Oct 26 2018
version 15.5
service password-encryption
hostname XXX
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging buffered
enable password 7
aaa new-model
aaa authentication login default local
aaa authorization console
aaa authorization exec default local
aaa session-id common
ethernet lmi ce
crypto pki trustpoint TP-self-signed-1280434013
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1280434013
revocation-check none
rsakeypair TP-self-signed-1280434013
crypto pki certificate chain TP-self-signed-1280434013
certificate self-signed 01
XXXXXX
quit
ip vrf INET
rd 1:100
ip dhcp excluded-address 10.10.1.1 10.10.1.10
ip dhcp excluded-address 10.0.6.1 10.0.6.10
ip dhcp excluded-address vrf INET 10.0.4.1 10.0.4.9
ip dhcp excluded-address vrf INET 10.0.4.201 10.0.4.254
ip dhcp excluded-address vrf INET 10.0.5.1 10.0.5.9
ip dhcp excluded-address vrf INET 10.0.5.201 10.0.5.254
ip dhcp excluded-address vrf INET 10.0.0.1 10.0.1.0
ip dhcp pool XXX
vrf INET
network 10.0.0.0 255.255.252.0
default-router 10.0.0.1
domain-name XXX
dns-server 10.0.4.1 8.8.8.8
class dhcp_class_unsecure
ip dhcp pool XXX
vrf INET
network 10.0.4.0 255.255.255.0
default-router 10.0.4.1
domain-name XXX
ip dhcp pool XX
network 10.0.6.0 255.255.255.0
default-router 10.0.6.1
ip dhcp pool XX
vrf INET
network 10.0.5.0 255.255.255.0
default-router 10.0.5.1
domain-name XXX
ip dhcp class dhcp_class_unsecure
remark limit IP Address
ip host XXX 10.0.4.1
ip host XXX 10.0.7.2
ip host XXX 10.0.4.2
ip name-server 8.8.8.8
ip multicast-routing
ip cef
login on-failure log
login on-success log
no ipv6 cef
flow record nbar-appmon
match ipv4 source address
match ipv4 destination address
match application name
collect interface output
collect counter bytes
collect counter packets
collect timestamp absolute first
collect timestamp absolute last
flow monitor application-mon
cache timeout active 60
record nbar-appmon
parameter-map type inspect global
max-incomplete low 18000
max-incomplete high 20000
nbar-classify
license udi pid C892FSP-K9 sn FCZ2041E3D6
archive
log config
logging enable
notify syslog contenttype plaintext
hidekeys
object-group service INTERNAL_UTM_SERVICE
object-group network local_cws_net
object-group network local_lan_subnets
any
object-group network vpn_remote_subnets
any
no spanning-tree vlan 20
vtp domain XXXXX
vtp mode transparent
vtp version 2
username XXX privilege 15 secret 5
vlan 20
name INTERNET
vlan 22
vlan 100
name XX
vlan 101
name XXX
vlan 102
name XXXX
vlan 103
name XXXXX
vlan 104
name XXXXXX
vlan 1004
bridge 0
stp type ieee
track 2 ip sla 2 reachability
delay down 60
track 3 ip sla 3 reachability
delay down 60
track 4 interface Vlan20 line-protocol
delay down 3 up 3
track 5 list boolean and
object 2
object 3
delay down 3 up 3
track 6 list boolean or
object 4 not
object 5 not
delay down 3 up 3
class-map type inspect match-any INTERNAL_DOMAIN_FILTER
match protocol msnmsgr
match protocol ymsgr
class-map match-all cmap1
match protocol cisco-phone-audio
match protocol cisco-phone-audio potentially
policy-map policy1
class cmap1
bandwidth percent 25
policy-map policy2
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
crypto keyring PUBLIC vrf INET
pre-shared-key address XXXXXXXXXXXX key XXXXXXXXXXX
crypto isakmp policy 1
encr aes
authentication pre-share
group 14
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 60 5
crypto ipsec transform-set trans2 esp-aes esp-sha-hmac
mode transport
crypto ipsec profile vpnprof
set transform-set trans2
interface Tunnel0
bandwidth 100000
ip address 10.3.0.1 255.255.255.0
ip mtu 1400
ip nhrp authentication XXXXX
ip nhrp map 10.3.0.254 XXXXXXXXX
ip nhrp map multicast XXXXXXXXX
ip nhrp network-id 100
ip nhrp holdtime 60
ip nhrp nhs 10.3.0.254
ip nhrp registration no-unique
ip nhrp registration timeout 30
ip tcp adjust-mss 1360
delay 1000
tunnel source Vlan21
tunnel destination XXXXXXXXX
tunnel key 100001
tunnel vrf INET
interface GigabitEthernet0
switchport mode trunk
no ip address
interface GigabitEthernet1
no ip address
shutdown
interface GigabitEthernet2
switchport access vlan 21
no ip address
no cdp enable
spanning-tree portfast
interface GigabitEthernet3
switchport access vlan 20
no ip address
no cdp enable
interface GigabitEthernet4
switchport access vlan 100
no ip address
interface GigabitEthernet5
switchport access vlan 22
no ip address
no cdp enable
interface GigabitEthernet6
no ip address
shutdown
interface GigabitEthernet7
no ip address
shutdown
interface GigabitEthernet8
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet9
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip vrf forwarding INET
no ip address
no ip redirects
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
no ip route-cache
shutdown
interface Vlan2
no ip address
interface Vlan20
description XXXXXXXXX
ip address XXXXXXXXXXX 255.255.255.252
ip nat outside
service-policy input policy2
interface Vlan21
description XXXXXXXXXXX
ip address XXXXXXXX 255.240.0.0
ip nat outside
shutdown
interface Vlan22
ip address XXXXXXXXXX 255.255.255.248
ip nat outside
interface Vlan100
ip address 10.0.0.1 255.255.252.0
no ip redirects
no ip proxy-arp
ip pim sparse-dense-mode
ip nat inside
no ip route-cache
interface Vlan101
ip address 10.0.4.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
no ip route-cache
interface Vlan102
description XXXXXX
ip address 10.0.5.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
no ip route-cache
interface Vlan103
ip address 10.0.6.1 255.255.255.0
no ip redirects
no ip proxy-arp
no ip route-cache
interface Vlan104
description XXXXXXX
ip address 10.0.7.1 255.255.255.0
no ip redirects
no ip proxy-arp
no ip route-cache
router eigrp 1
network 0.0.0.0
passive-interface default
no passive-interface Tunnel0
eigrp stub connected summary
ip forward-protocol nd
ip http server
ip http upload enable path flash:
ip http upload overwrite
no ip http secure-server
ip http path flash:
ip tftp source-interface GigabitEthernet0
ip dns view default
dns forwarder vrf INET 8.8.8.8
dns forwarding source-interface Vlan100
ip dns server
ip nat inside source list 1 interface Vlan22 vrf INET overload
ip route vrf INET 0.0.0.0 0.0.0.0 172.16.0.1 10 track 6
ip route vrf INET 0.0.0.0 0.0.0.0 XXXXXXXXXX 25
ip ospf name-lookup
ip ssh version 2
ip scp server enable
ip access-list extended nat-list
permit ip object-group local_lan_subnets any
ip sla 1
icmp-echo 10.3.0.254 source-interface Vlan2
frequency 30
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.8.8 source-interface Vlan20
vrf INET
frequency 10
ip sla schedule 2 life forever start-time now
ip sla 3
icmp-echo XXXXXXXXX source-interface Vlan20
vrf INET
frequency 10
ip sla schedule 3 life forever start-time now
logging source-interface Vlan104
logging host XXXXXXXXX
route-map NAT permit 10
match ip address 1
snmp-server group groupRW v3 priv read IPL
snmp-server group XXXXXXXXXL v3 auth
snmp-server view IPL iso included
snmp-server trap-source Vlan104
snmp-server enable traps snmp coldstart warmstart
snmp-server enable traps envmon fan shutdown supply temperature
snmp-server host 172.31.0.4 IPL
access-list 1 permit 10.0.0.0 0.0.3.255
access-list 1 permit 10.0.4.0 0.0.0.255
access-list 1 permit 10.0.5.0 0.0.0.255
access-list 99 permit 10.1.0.0 0.0.0.255
access-list 99 permit XXXXXXXXX 0.0.0.15
access-list 99 permit XXXXXXXXX 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
password 7 01100F175804
logging synchronous
no modem enable
line aux 0
line vty 0 4
privilege level 15
password 7 XXXXXXXXX
logging synchronous
transport input ssh
line vty 5 15
privilege level 15
logging synchronous
transport input ssh
scheduler allocate 20000 1000
ntp server XXXXXXXXXXX
ntp server 10.1.0.254
event manager applet TRACK_INET_DOWN
event track 6 state up
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "int tun 0"
action 4.0 cli command "shutdown"
action 5.0 cli command "tunnel source vlan 21"
action 6.0 cli command "no shut"
action 6.1 cli command "exit"
action 6.2 cli command "do clear ip nat translation forced"
action 6.3 cli command "no ip nat inside source list 1 interface vlan 20 vrf INET overload"
action 6.4 cli command "ip nat inside source list 1 interface vlan 21 vrf INET overload"
action 7.0 cli command "end"
action 8.0 syslog msg "Primary INET DOWN - Activate Backup Connection"
event manager applet TRACK_INET_UP
event track 6 state down
action 5.0 cli command "tunnel source vlan 20"
action 6.3 cli command "no ip nat inside source list 1 interface vlan 21 vrf INET overload"
action 6.4 cli command "ip nat inside source list 1 interface vlan 20 vrf INET overload"
action 8.0 syslog msg "Primary INET UP - Deactivate Backup Connection"
event manager applet storePreferences
event none sync yes
action 1 file open LOG flash:ccpexp/preferences.JSON w+
action 2 file puts LOG "{"analytics":false,"ccpTheme":true,"writeMemory":false,"japIPSEnable":false,"recmndSecrtySettings":false,"analyticsOpened":false,"overrideThemePreference":false,"adminEnabledCommandsForMonitorStr":""}"
action 3 file close LOG
end
Hello
So just to confirm you did have ssh access before correct?
How are you trying to access the router - FYI you need to be accessing  it from the subnets specified in access-list 99.
Also are you trying to access the router via one of its vrf  interfaces
can appy try the following: and test telnet and ssh and let us know if you can gain access via telnet and/or ssh
Conf t
line vty 0 15
no access-class 99
end
Kind Regards
Paul
rasmus.elmholt
Level 7
Level 7
If you have an access-class on your VTY lines with a deny any statement, then remote access isn't possible.
Normally when you connect you use up the first vty lines from 0 upwards.
So when the first 5 users login they will be validated against ACL 23 and then the rest will be validated against ACL99.
When a user logs out the VTY line will be freed up for someone else to use(show line)
Do you have configured a user and how does your AAA lines look? (show run | inc aaa)
Maybe more than 15 users have logged in and abandoned their session? (show users)
Or the SSH key hasn't been generated? ( show crypto key mypubkey all )
These are some of the problems I often see when SSH isn't working.
