SSH support on 3825
g-pate
Can anyone tell me if SSH is supported on the 3825 platform with this IOS release?
Release 12.4(15)XY
What I need is a release that supports SSH and a NME-TPO
pkaretnikov
It appears that all the images that are not marked with w/o crypto spport SSH. You should be able to do what you are looking for with even the IP base image.
The NME-TPO lists this as it's requirement
'Cisco IOS Software Release 12.4(15)XY or later'
so any of the feature sets should support it.
Hope that helps.
Harold Ritter
Gary,
You can use the Cisco Feature Navigator to very availability of a certain feature in a given IOS release.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
pkaretnikov
Hope that helps.
