SSH with VRF
dndncr101
I'm having issues with SSH on my 3750G-12S.  I'm not able to SSH to another switch when VRFs are configured.
I've tried ip ssh source-interface, ssh -vrf doesn't exsist and I've upgraded the IOS to the latest version.
Has anyone seen this before?
5 Replies 5
Pavel Bykov
Level 5
Level 5
Have you tried ssh /vrf ?
I did try /vrf and it still doesn't work.  The issue is that there are no vrf commands after ssh.
It's funny but telnet does have the -vrf command.
Unfortunately, it seems that on 3750/3560 this is not supported:
VRF-aware support for HSRP, uRPF, ARP, SNMP, IP SLA, TFTP, FTP, syslog, traceroute, and ping
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/release/notes/OL23054.html
Meaning, there is no VRF-awareness for SSH. At least it is not mentioned in the documentation, and as you said there is no command for it.
Normally, it's like this:
u240#ssh ?
  -c    Select encryption algorithm
  -l    Log in using this user name
  -m    Select HMAC algorithm
  -o    Specify options
  -p    Connect to this port
  -v    Specify SSH Protocol Version
  -vrf  Specify vrf name
  WORD  IP address or hostname of a remote system
I just heard from Cisco that its in the road map but no there is no ETA.
I have a fix for now, until the IOS is updated.
sanjeev.3.singh
similar issue but with C1760 & WS-C2950-24
